I've recently been having intermittent headlight issues where the car flags up a fault with the left headlight every time the car is started and it fails to light up until the lights are turned off and on again, and then it works and stays on.
I decided to run a fault scan to see if there was any pointers and got the following:
OBDeleven data log
Date: 2020-01-25 15:35
VIN: WAUZZZ8PX7A097986
Car: Audi S3
Year: 2007
Body type: Hatchback
Engine: BHZ 195 kW (265 HP) 2.0 l
Mileage: 215440 KM
00 Steering Angle Sender
Trouble codes:
No trouble codes found
01 Engine Control Module 1
System description: 2.0l R4/4V TFSI
Software number: 8P0907115H
Software version: 0050
Hardware number: 8P0907115B
Serial number: AUX7Z0F9FNI0MR
Long coding: 01030003180F0160
Trouble codes:
P0087 - Fuel Rail/System Pressure - Too Low Lower limit not reached
Intermittent
Priority: 0
Frequency counter: 2
Driving cycle: 255
Mileage: 215272 km
Date: 2020-01-25 11:20:33
03 Brakes 1
System description: ESP 4MOTION MK60
Software number: 1K0907379AB
Software version: 0102
Hardware number: 1K0907379AB
Coding: 0021128
Trouble codes:
04 Steering Angle Sender
Trouble codes:
08 Air Conditioning
System description: KlimavollautomatH19
Software number: 8P0820043AD
Software version: 0360
Hardware number: 8P0820043AD
Hardware version: 000
Serial number: 8P0820043AD
Trouble codes:
01232 - Compr. regulator valve, A/C Sys. Open circuit/short circuit to B+
static
Priority: 2
Frequency counter: 176
Driving cycle: 195
Mileage: 213491 km
Date: 2019-12-27 09:44:11
09 Central Electrics
System description: Bordnetz-SG H43
Software number: 8P0907279F
Software version: 1201
Hardware number: 8P0907279F
Hardware version: 063
Serial number: 00000006287839
Long coding: ED8E5F27A014100000000000000000000009EE175A0500
Subsystems:
System description: Wischer AU350 H01
Software number: 8P2955119E
Software version: 0130
Coding: 0064784
System description: REGENLICHTSENSORH13
Software number: 4E0910557A
Software version: 0090
Coding: 0150573
Trouble codes:
00978 - Left low beam headlamp bulb Open circuit/short circuit to B+
static
Priority: 1
Driving cycle: 195
Mileage: 215447 km
Date: 2020-01-25 15:36:00
15 Airbag
System description: Airbag 9.41 H12
Software number: 8P0959655H
Software version: 3720
Hardware number: 8P0959655H
Serial number: 0037W0G0GA64
Coding: 0071612
Trouble codes:
16 Steering Column Electronics
System description: J0527 H36
Software number: 8P0953549F
Software version: 0070
Hardware number: 8P0953549F
Coding: 0004042
Subsystems:
System description: E0221 H07
Software number: XXXXXXXXXXX
Trouble codes:
01304 - Radio No signal/communication
static
17 Dash Board
System description: KOMBIINSTR. VDO H20
Software number: 8P0920981J
Software version: 0570
Hardware number: 8P0920981J
Serial number: 2249F004000156
Coding: 0037418
Trouble codes:
19 Gateway
System description: J533__Gateway H12
Software number: 1K0907530J
Software version: 0160
Hardware number: 1K0907951
Serial number: 3200106A068321
Long coding: FD0F078007000101
Trouble codes:
22 All Wheel Control
System description: Haldex 4Motion
Software number: 1K0907554F
Software version: 0115
Coding: 0000001
Trouble codes:
25 Immobilizer
Trouble codes:
42 Door Electronics Driver Side
System description: Tuer-SG 020
Software number: 8P0959801G
Software version: 0110
Coding: 0000632
Trouble codes:
01552 - Driver door central locking LOCK motor Electrical error in circuit
Intermittent
00928 - Lock unit for central locking Driver side Implausible signal
Intermittent
44 Steering Assistance
System description: EPS_ZFLS Kl. 69
Software number: 1K0909144H
Software version: 2901
Trouble codes:
46 Central Module Comfort System
System description: KSG H04
Software number: 8P0959433C
Long coding: 189000186D28850D489AC63300
Subsystems:
System description: Neigungssensor 005
Software number: 1K0907719C
Software version: 0003
System description: Innenraumueberw.H04
Software number: 8P0951177
Software version: 0020
Trouble codes:
52 Door Electronics Passenger Side
Software number: 8P0959802H
Coding: 0000632
Trouble codes:
55 Headlight Regulation
System description: AFS 1 H01
Software number: 4F0910357F
Hardware number: 4F0907357F
Coding: 0000020
Subsystems:
System description: AFS-Modul links H03
Software number: 8E0941329A
System description: AFS-Modul rechtsH03
Trouble codes:
76 Parking Assistance
System description: Parkhilfe 4-Kan H09
Software number: 8P0919283D
Software version: 0060
Hardware number: 8P0919283D
Serial number: 00067824830628
Coding: 0000113
Trouble codes:
77 Telephone
System description: FSE_255x BT H26
Software number: 8P0862335H
Software version: 0290
Hardware number: 8P0862335H
Serial number: 00000005036299
Coding: 0011422
Trouble codes:
static
Priority: 5
Driving cycle: 191
Mileage: 215069 km
Date: 2020-01-23 17:02:20
There are a few faults in there relating to a ground/earth issue so I'm hoping these are all related and can be resolved if I find the source of the issue, so any pointers would be appreciated.
Also, whilst sat in the car with the engine running after a 2 hour drive (engine very hot) I noticed smoke from the exhaust in my mirror. The smoke smelled like burning oil, so I stopped the engine and checked the dipstick, and whilst the oil was at the halfway mark (not a significant drop since the last check) I topped it up and started the engine again, this time no smoke!
I did notice the fault code relating to low fuel pressure and think it's been about 30k since the Cam follower was changed, so I've ordered a new one and will swap them over tomorrow (Amazon Prime is a god send!) but I wondered if this could be related to the oily smell in the smoke, or do I need to look for something else?
I know this is a long post, so thank you if you read it all and any replies are appreciated.
OBDeleven data log
Car: Audi S3
Year: 2007
Mileage: 215440 KM
Trouble codes:
Trouble codes:
Intermittent
Priority: 0
Driving cycle: 255
Mileage: 215272 km
03 Brakes 1
Coding: 0021128
Trouble codes:
Trouble codes:
08 Air Conditioning
Trouble codes:
static
Priority: 2
Driving cycle: 195
Mileage: 213491 km
Subsystems:
Coding: 0064784
Coding: 0150573
Trouble codes:
static
Priority: 1
Driving cycle: 195
Mileage: 215447 km
15 Airbag
Coding: 0071612
Trouble codes:
Coding: 0004042
Subsystems:
Trouble codes:
static
17 Dash Board
Coding: 0037418
Trouble codes:
19 Gateway
Trouble codes:
Coding: 0000001
Trouble codes:
25 Immobilizer
Trouble codes:
Coding: 0000632
Trouble codes:
Intermittent
Intermittent
Trouble codes:
Subsystems:
Trouble codes:
Coding: 0000632
Trouble codes:
Coding: 0000020
Subsystems:
Trouble codes:
Coding: 0000113
Trouble codes:
77 Telephone
Coding: 0011422
Trouble codes:
static
Priority: 5
Driving cycle: 191
Mileage: 215069 km
