Team Traxxion
- Joined
- Sep 24, 2015
- Messages
- 7
- Reaction score
- 0
- Points
- 1
Hi Guys
Is anyone able to shine some light on this fault code please? My carfeels under powered, and when I run VCDS it shows this.
Any help would be much appreciated. As you can see, it's hardly high mileage!
Thanks in advance.
Chris
2 Faults Found:
19404 - Turbo/Super Charger Boost System
P2263 00 [172] - Performance
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 114
Mileage: 17098 km
Date: 2017.03.04
Time: 15:36:01
Engine speed: 1045.50 /min
Normed load value: 15.7 %
Vehicle speed: 0 km/h
Coolant temperature: 80 °C
Intake air temperature: 45 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.567 V
Unlearning counter according OBD: 40
Charge pressure actuator: specified position: 140.00 %
Bypass valve f high press turboch turbine inlet: actual value: 132.45 %
Charge pressure actuator: adaptation for lower stop: 3439.0 mV
Bypass valve for high press turbocharger turbine inlet: status-Bit 0: 0
Bypass valve for high press turbocharger turbine inlet: status-Bit 16: 0
Bypass valve for high press turbocharger turbine inlet: status-Bit 24: 55
Bypass valve for high press turbocharger turbine inlet: status-Bit 8: 66
Bypass valve for high press turboch turbine inlet: uncond volt: 4581.0 mV
Charge air pressure: actual value: 978.75 hPa
17141 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [237] - Malfunction / Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 17098 km
Date: 2017.03.04
Time: 15:35:59
Engine speed: 1250.00 /min
Thanks in advance.
Chris
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Mileage: 17098 km
Date: 2017.03.04
Time: 15:36:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 17098 km
Date: 2017.03.04
Time: 15:35:59
