FAULT CODE HELP PLEASE
1wheelonly
cabriolet
The Lounge
not getting any response from the a4 clan so i thought id ask the a3 lot as theres ****** hundreds of you.
My ecu light keeps coming on, reset it a couple of times but it comes back so must have a fault.
here is the fault from my scan, could anyone tell me what it means and what part i need to cure it,also whats involved to fit it.cheers
Address 01: Engine Labels: None
Part No SW: 8E0 909 518 AL HW: 8E0 909 018 A
VIN: 000000000000000 Mileage: 98780km/61379miles
Component: 1.8L R4/5VT 0003
Coding: 0011504
Shop #: WSC 00672
1 Fault Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
Readiness: 0000 0000
http://wiki.ross-tech.com/index.php/16804/P0420/001056
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
  • Leakage in Intake and/or Exhaust System
  • Catalyst faulty
  • Oxygen Sensor(s) faulty
  • Oxygen Sensor(s) Control faulty
Possible Solutions
  • Check Intake and Exhaust System for Leaks
  • Check Catalyst
  • Check Oxygen Sensor(s)
  • Check Oxygen Sensor(s) Control
    • Perform Oxygen Sensor(s) Aging Check
Special Notes
Retrieved from "http://wiki.ross-tech.com/index.php/16804/P0420/001056"
Are you on an OEM exhaust and if so is it leak free?
If yes then I would suggest 02 sensor changed first.
stu
just had a suggestion that the cat might be ******** but just passed mot, thought they took readings.
not long had new exhaust system OEM but only from cat back, would it need to be leeking before the cat.
I think a leak anywhere from the manifold to the 02 sensor will cause an issue.
There are some tests that can be carried out with VAS/VCDS to test the 02 sensors etc so it might be worth an hours labour if you can't do it yourself.
It's a variant of the 1.8t.
I would think the tests would be ok for yours.
PM me an email address and I'll send it over.
