Facelift Reversing Camera
M1ke Jones Sep 24, 2017
  1. M1ke Jones
    M1ke Jones New Member
    Just a quick post to confirm I have completed OEM reversing camera install on my 2015 FL A6 Avant. This has MIB2 MMI (tech pack). All the basics of the install are well covered elsewhere but hopefully the following will assist anyone else.
    1. Camera Control Unit - FL cars are supposed to have an updated control unit but they seem to fetch big money on Ebay so I decided the try the pre FL unit which has a 54 pin connector. There are only 6 wires to connect to it so hardly worth buying the loom. There is is CAN bus connector block next to the fuses (2 wires) then power/gnd - I fitted a connector to a spare fuse slot. Last two are camera pos/neg.
    2. MMI (5F) coding - this is no longer in the long coding. It is now an adaptation. There are two VPS entries, enable the first and set the second one to Terminal 15 - there is also a code required on Central Electrics (09) Byte 35 bit 4 to 1.
    Everything is was straightforward (if not time consuming) just have to be careful not to break clips.
    Next will be to try and calibrate it using a homemade calibration board. Thanks to Alex from vag car coding for his assistance with the adaptation on the 5F - you don't need the dongle that others sell for loads of money. Happy to provide any help clarification if needed.
  2. Avatar
    Google AdSense Advertisement
  3. craig20102010
    craig20102010 Member
    106
    14
    Got a photo of the camera installed and it on the screen?
  4. NHN
    30,358
    1,978
    Did an A5 over the weekend with 3g, there's a hidden bit to set in byte 35 of module 09 iirc which sets to auto view camera instead of parking sensors, the byte on is usually set to 24, changed to 34 & default view is camera with sensor view to the right, still switchable with a button.
    Go into mmi parking menu, turn of display then back on & this should set the view with cam.
  5. craig20102010
    106
    14
    Who can I get in touch with to add some of these software mods to my car?
  6. NHN
    30,358
    1,978
    Subject to location, pm me bud.
  7. phos4
    phos4 New Member
    Hey there..
    Were did u connect the pos and neg wire of the camera..
