Q7 Extended Wheel Bolts for H&R Spacers
GaryDe Sep 4, 2018
  1. GaryDe
    GaryDe Active Member
    Hi all,
    I've recently purchased a 2012 Q7 and started my mods by purchasing some 30mm H&R spacers for the rear and 23mm H&R spacers for the front.
    Unfortunately I didn't realise the 23mm set would require longer wheel bolts as they do not attach in the same way as the 30mm set (where they bolt to the hub and then the wheel bolts to the spacer using the original bolts).
    Can anyone advise where I can purchase the longer wheel bolts and what size I would need for 23mm spacers?
    Thanks...
  2. Avatar
    Google AdSense Advertisement
  3. T-800
    T-800 Well-Known Member VCDS Map User
    3,128
    3,052
    Check out CM Wheels.
    I bought my H&R spacers / bolts / lockers off them.
