Extended service interval oil change settings
Jeffry
Sofia
Hi Guys,
Could anybody tell me are the below setting for extended service interval oil change is correct. That are the setting which service made when they change oil a few mounts ago. I have doubts about the competence of this service and I want to check if the settings are correct.I bought VAG cable and software soon and while I was looking at my oil change settings I noticed that the value for “IDE00515-ESI: oil quality” is “poor oil quality”. I have read that for the Extended Service Interval Oil Change this must be set to “good oil quality” but not “poor oil quality”! If it is correct can I change it now on “good oil quality” and it is necessary to change the value for “soot entry” too?
The car is Audi A8 4.2 TDI, 2013.
Mileage: 81212km-50462mi Repair Order:
VCDS Release 18.2.0: SRI Reset-SRI1.CLB
Control Module Part Number: 4H0 920 830 R Labels: .4H0-920-xxx-17.clb-SRI1
Component:TDieRDWACCNV- H53 0621, Coding:13860800BF550008000000
Operation: Please select an operation
Channel Description Current val. New val.
IDE00342-ESI: Resetting ESI ESI: Service Reminder Status no warning ---
IDE00510-ESI: distance driven from inspection ESI: Distance since Inspection 7600 km ---
IDE00511-ESI: time from inspection ESI: Time since Inspection 192 Days ---
IDE00515-ESI: oil quality ESI: Oil Quality poor oil quality ---
IDE00517-ESI: soot entry ESI: Soot Quantity 24700 km ---
IDE00518-ESI: thermal load ESI: Thermal Load 9600 km ---
IDE01153-SIA: maximum value of distance to service SIA: Maximum Distance to Service 30000 km ---
IDE01154-SIA: maximum value of time to service SIA: Maximum Time to Service 730 Days ---
IDE03349-FIX: Max. distance until next mileage-related inspection FIX: Maximum Distance to Inspection 30000 km ---
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Maximum Time to Inspection 730 Days ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance since Inspection 7600 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time since Inspection 192 Days ---
5K
dik
