Pretty sure that decat has been a problem for mot even before the latest changes... Getting decat has three options:What's the deal now with getting exhausts fitted since the new stricter MOT rules have come in to place?
I take it de-cat is now out the window?
I had a 200cel cat on my S3 and it was still quite restrictive at Stg3, but up to Stg2+ the cat supplied by BCS seems to flow well enough and not rob you of too much power.I would start to think off Sport cat with enough cells to pass the emissions test and you should be fine or keep stock exhaust and you will defo be fine .
But if your a Rebel go the other way and get rid off the cats .
I have a 200 cel APR cat and that doesnt seem to cause any issues even mated to a stock system. A decat and a non res system might flow better ? but its difficult to see where it would improve my dyno chart so it wouldn't be a priority for me as i am running near the limit of my turbo output already. the APR cast downpipe and cat is a mini work of art, ****** expensive but the finish they get on the inside of the pipework without welds is amazing. Quite how they machine the inside of the welded cat tubes is beyond me but they are mirror finish inside.
I've a Miltek sports Cat.
I failed my MOT on emissions so went somewhere where they could turn a blind eye.
Not sure if some sensors on my exhaust aren't a bit dodgy my fuel is running rich
I usually pop mine along to the garage it does my car and get him to check it will pass before it heads to the Mot .never failed yet but there is always a first so keeping fingers n toes crossed come Feb 2019Yea first time it wasn't
Second time I went for quite a long run revving a lot low gears kept the car running. Waited a bit before a re-run the results were better but still failing.
The tuners reckon maybe lumbar sensor is faulty.
