Exhaust Manifold Removal
Sp3no82 May 14, 2018
  1. Sp3no82
    Sp3no82 Member
    129
    21
    I have a leak on what I think must be my exhaust manifold, there is lots of soot around the top of the turbo and with a Cam Belt change planned for this weekend I think I'm going to address this issue at the same time.
    I have a turbo gasket set and exhaust manifold gasket but I have just read the Haynes manual on how to remove the manifold and it seems like an unnecessarily massive job. Do I need to really remove the drive shaft, I have recently fitted new hub bolts and had to borrow a 4ft wrench to do the bloody thing back up again and I don't really fancy going though all that again.
    You guys got any tips before I crack this, I'm not 100% its the manifold leaking but there is a ton of soot in that area and it sounds like a manifold leak.
  2. Avatar
    Google AdSense Advertisement
  3. Sygh2k
    Sygh2k Active Member Gold Supporter
    119
    34
    quattro/2wd, engine info detail would help
  4. Sp3no82
    Sp3no82 Member
    129
    21
    2.0tdi 170 2wd Avant manual :)
  5. Sygh2k
    119
    34
    i dont know about the tdi but i would definetly soak bolts if theyv never been out with penetrating fluid, unforunately i have a tfsi so not much help on tdi'
  6. jay1601
    jay1601 Well-Known Member
    1,404
    98
    You don’t need to remove the drive shaft when changing the turbo.
    Could be EGR causing exhaust leak.
    Removing the turbo off the 2.0TDi is a easy job.
