Exhaust for rsq3?
Gavin96 Oct 29, 2018
  1. Gavin96
    Gavin96 Member
    69
    32
    Hi folks i hope your all well. I have Been snooping round for an exhaust system for my rs and there is not much around for my car, suposedly because you have to get round the battery in the rear of the boot which is a problem. I have found 2 companies so far that will do an exhaust system. One with supersprint, and another company called tony banks custom exhaust systems in leeds. Any ideas on if the custom exhaust system is any good as its a lot cheaper than the supersprint exhaust? Cheers gav
  2. Avatar
    Google AdSense Advertisement
  3. RS_Dan
    RS_Dan Guest
    Are you wanting to retain the ecu controlled valve? Like the Supersprint system
    BCS do a down pipe and sports cat (keeping the catback) but you’d need a remap.
    Have you seen PCW Exhaust Mods? If you are only after a bit more noise then this might be an option.
  4. Gavin96
    Gavin96 Member
    69
    32
    Hi dan, no i am not looking at having a valved controlled exhaust system.
    I just want something to give my audi that nice rs grumble / pop and bang sound that my last one had, as i was a bit dissapointed how quiet mine is currently standard. And remap wise i would probably go to unicorn motors as they are a 5 minute drive from mine and have talked me thru what they would get for my vehicle. Cheers gav.
  5. RS_Dan
    RS_Dan Guest
    The current OEM system is valve controlled so removing it might flag an error but if you plan to have it mapped then they will be able to sort that.​
    This is a forum members car after the exhaust has been modified by PCW
  6. Gavin96
    Gavin96 Member
    69
    32
    Hi dan, yes that does sound better to be fair might look further into that cheers.
  7. HawkeyeS3
    HawkeyeS3 Well-Known Member TeamMisano Audi RSQ3 quattro Audi A1
    645
    445
    Determining an exhaust is one thing - however do look at the cost of getting a replacement rear valence modified and fitted before committing, as most - if not all - aftermarket systems are twin outlet. Trust me, not cheap!
  8. Gavin96
    Gavin96 Member
    69
    32
    Ah ok thanks for the advice hawkeyes3 !
