M7R
Type Approval Engineer,
- Joined
- Sep 9, 2008
- Messages
- 216
- Reaction score
- 2
- Points
- 18
- Location
- Chilwell, Notts
- Website
- www.dubclique.com
i have a 12 plate exeo (basically a B7 A4 S line with a CR engine), the wife normally drives it but I have been using it a fair bit lately and the radio is driving me nuts! The FM signal sounds like a skipping CD. This is on a RNSE unit, the later ones with the better screens etc.
I did play with some of the settings a while ago and tbh I'm not sure if it's something I've set causing it to keep looking for a stronger signal and swapping, or that the FM booster is balls (not scanned it with VCDS yet will do that it a bit).
Is this an issue other have had? I listen to BBC Radio 2 a lot so it's not like it's a local weak signal radio station.
Could anyone with a rnse who has good signal tell me what their settings are when you are on the radio, and then press settings. Mostly it's for the alt freq, regional and sensitivity settings.
