Everything is malfunctioning
Steve-greek Jul 1, 2018
  1. Steve-greek
    Steve-greek New Member
    14
    Hello Everyone.
    Hopefully someone will be able to suggest where to start with this one.
    Driving my A6 2006. Got to a hill, put the parking brake on. Went to pull away as normal and the car just lit up like a Christmas tree, flashing red lights. Handbrake did realise.
    The Car went into limp, no power.
    Lost my speedo,
    Power Steering went heavy
    ABS light on
    Traction Light on
    Electronic handbrake malfunction in DIS. And not working.
    Did a quick scan and 6 modules are showing malfunction?
    Chassis Type: 4F0
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61 62 72
    Mileage: 99390km-61758miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Only Fault codes are:
    Address 19: CAN Gateway Labels:. 4F0-910-468.clb
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 13008069278032
    Coding: 6CEE53C41B2104
    Shop #: WSC 02334 785 00200
    VCID: 275D4D9E96ED127C79-8072
    1 Fault Found:
    00470 - Company Comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 99390 km
    Time Indication: 0
    Date: 2018.07.01
    Time: 21:44:52
    AND
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000289758
    Coding: 0001104
    Shop #: WSC 02323 785 00200
    VCID: 5EB3287A893793B44A-800A
    1 Fault Found:
    01316 - ABS Control Module
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 99388 km
    Time Indication: 0
    Date: 2018.07.01
    Time: 21:44:00
    Freeze Frame:
    Voltage: 11.900 V
    Temperature: 32.0°C
    Im dont even have a clue where to start with this. Any help would be a big help
  2. Avatar
    Google AdSense Advertisement
  3. Stokka
    Stokka Active Member
    100
    42
    I dont know if this may be the same, but on my passat with an EPB after wading thru slush ( IE having fun) I had got water in one of the jacks on the back of the EPB motor, the dash was blinking several lights. I wouldn't know about limp mode because i could not move.
    I solved it with water dispeller
    Had you been wading through water or deep puddles ?
  4. Steve-greek
    14
    With this weather, it hasn't seen water now for at least 2 weeks.
  5. Steve-greek
    14
    Anyone Got any idea where i need to start on this one?
  6. ch1z64
    ch1z64 C'mon you's bhoy's in Green Team Imola TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    3,204
    657
    Depending where you stay it might be worth sending a PM to either off these guys depending which 1 is closer @NHN or @Ash187 .
