DriverN00B
Earlier on today, all of a sudden after a refuel the ESP light came on, and the DSG stopped shifting up until it hit redline. Moments later the ABS light also came on! So after a quick search it became apparent that the most likely cause of this would be a rear wheel speed sensor. Just checked with VCDS, turns out it's the rear left sensor. Along with this the Auto came back with the following fault -
18255/P1847/006215 - Please check DTC Memory of ABS Controller
Will this be linked to the failing speed sensor?
Also after running the scan and whilst clearing faults, some grinding noises could be heard from the gearbox with the engine not running but ignition on, these went as soon as I turned ignition off and back on?
Thanks!
Thanks!
