  2. Dismiss Notice
ESP 8.0 ABS Module Coding Help
solo786 Oct 28, 2014
  1. solo786
    solo786 Boosting..
    Hello All,
    I am relatively new to this board, and require some very urgent assistance with my A6. I have searched the forums and have found nothing conclusive.
    Basically I had the notorious G201 Brake Pressure sensor fail in my abs module. I wasn't aware at the time of services such as BBA Reman & Module Masters at the time, so I purchased a 2nd hand unit on ebay.
    My original ABS module part number was 4F0614517L, as inscribed on the hydraulic unit. The part I purchased has the identical part number as well.
    I changed the units out and bled the brakes, only to see a few different trouble codes appear. See here;
    Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
    Part No SW: 4F1 910 559 C HW: 4F1 907 559
    Component: 3.2l V6 FSI 0010
    Revision: --H15--- Serial number:
    Coding: 01050400190F0120
    Shop #: WSC 02325 785 00200
    VCID: 2B53BF628AE505461EF-807E
    3 Faults Found:
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 008 -
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 43
    Reset counter: 193
    Mileage: 137799 km
    Time Indication: 0
    Date: 2014.10.18
    Time: 17:08:17
    Freeze Frame:
    RPM: 1056 /min
    Mass Air / Rev.: 130.8 mg/str
    Temperature: 42.0°C
    Idle
    Load: 16.9 %
    Speed: 0.0 km/h
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
    Component: ESP 8.0 quattro H03 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020875
    Shop #: WSC 02327 785 00200
    VCID: 2D57B17AB4F10B7600B-8078
    5 Faults Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 39
    Reset counter: 207
    Mileage: 137799 km
    Time Indication: 0
    Date: 2014.10.18
    Time: 17:42:56
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x47A2
    Hex Value: 0x001E
    Hex Value: 0x3EAC
    Hex Value: 0x00FF
    01321 - Control Module for Airbags (J234)
    000 - -
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 1
    Fault Frequency: 38
    Reset counter: 207
    Mileage: 137799 km
    Time Indication: 0
    Date: 2014.10.18
    Time: 17:45:34
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x4782
    Hex Value: 0x0014
    Hex Value: 0x309C
    Hex Value: 0x00FF
    01314 - Engine Control Module
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 38
    Reset counter: 207
    Mileage: 137799 km
    Time Indication: 0
    Date: 2014.10.18
    Time: 17:45:35
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x4782
    Hex Value: 0x0014
    Hex Value: 0x319C
    Hex Value: 0x00FF
    18055 - Check Coding of ECUs on Powertrain Data Bus
    P1647 - 000 -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 37
    Reset counter: 207
    Mileage: 137799 km
    Time Indication: 0
    Date: 2014.10.18
    Time: 17:45:35
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x4782
    Hex Value: 0x0014
    Hex Value: 0x209C
    Hex Value: 0x00FF
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 36
    Reset counter: 207
    Mileage: 137799 km
    Time Indication: 0
    Date: 2014.10.18
    Time: 17:49:54
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x47A2
    Hex Value: 0x0021
    Hex Value: 0x4194
    Hex Value: 0x00FF
    The G201 Brake Pressure sensor error has gone, and my cruise control works again - so im inclined to think that the module/pump i fitted works. Now when I start up the vehicle I get 3 loud beeps for brakes - and the lights continually flash when driving.
    I have managed to clear the steering angle fault (00778), and the System Function Test (01486)
    I cannot clear 18055, 01314, and 01321.
    Anyone with any assistance or information on how to do this would be greatly appreciated.
    I have mailed the full autoscan to Ross-Tech but I didnt receive any feedback from them - I do own a genuine vag-com hex-can-usb cable purchased from hexdiagnostics south africa. So I am a bit stuck for help.
  2. Avatar
    snack-media
    Advertisement
  3. gupsterg
    gupsterg Registered User
    348
    67
    Code:
    DTC 01321
    Fault Location:
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    When found in Audi A4 (8E) Brake Electronics (Bosch 8.0)
    Coding of Powertrain Control Modules wrong/incomplete.
    When found in Audi A8 (4E) Parking Brake
    Check Airbag Control Module for DTCs. DTC 00591 can cause this.
    Possible Solutions:
    Check Coding of Powertrain Control Modules, especially check the related Airbag 9.41 Adaptation Channels 050 & 051.
    Resolve any faults codes in the Airbag Module.
    After you swapped ABS unit did you changing coding to what was in your old ABS unit?
    Is airbag module showing a DTC?
