Car goes into limp mode every now and again just wondering if anyone on here can help me out as its frying my head here are the vag com vehicle scan
Sunday,17,January,2016,18:22:46:45112
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
www.Ross-Tech.com
VIN: WAUZZZ8P14A126464 License Plate: CHIPPY
Mileage: 224400km-139435mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P14A126464 Mileage: 224400km-139435miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 DS
Component: SIMOS71 1.6l 2V 5559
Revision: --H03--- Serial number: AUX7Z0D0FNK036
Coding: 0000071
Shop #: WSC 06435 000 00000
VCID: 73E27E17120510A666-8026
4 Faults Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 0 /min
Absolute Pres.: 1005.5 mbar
Load: 15.3 %
Load: 11.4 %
RPM: 0 /min
Load: 15.3 %
Load: 11.0 %
16955 - Brake Switch (F)
P0571 - 008 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 896 /min
Mass Air / Rev.: 81.8 mg/str
Bin. Bits: 00000100
RPM: 640 /min
Mass Air / Rev.: 103.6 mg/str
Bin. Bits: 00000100
P1639 - 006 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 0 /min
Load: 15.3 %
Load: 11.4 %
RPM: 0 /min
Load: 15.3 %
Load: 11.0 %
16725 - Camshaft Position Sensor (G40)
P0341 - 008 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 288 /min
Mass Air / Rev.: 267.1 mg/str
Bin. Bits: 00000010
Temperature: 67.5°C
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0019077
VCID: 3A7C933375EFA1EE65-806E
1 Fault Found:
01542 - Yaw Rate Sensor (G202)
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 025298 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
VCID: 2D56A86FB4A10656F0-8078
5 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 8
Reset counter: 92
Mileage: 221556 km
Time Indication: 0
Date: 2015.04.27
Time: 20:46:31
Freeze Frame:
Voltage: 13.50 V
Temperature: 8.5°C
(no units): 165.0
(no units): 35.0
Temperature: 8.0°C
01592 - Air Quality Sensor (G238)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 64
Mileage: 222082 km
Time Indication: 0
Date: 2015.05.12
Time: 15:12:57
Freeze Frame:
Temperature: 17.5°C
00710 - Defroster Flap Positioning Motor (V107)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 91
Mileage: 222727 km
Time Indication: 0
Date: 2015.05.27
Time: 21:22:12
Freeze Frame:
Voltage: 12.20 V
Temperature: 15.5°C
(no units): 232.0
(no units): 229.0
Temperature: 10.0°C
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 65
Mileage: 222089 km
Time Indication: 0
Date: 2015.05.12
Time: 17:23:26
Freeze Frame:
Temperature: 14.5°C
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 93
Mileage: 211664 km
Time Indication: 0
Date: 2014.08.13
Time: 11:18:22
Freeze Frame:
Temperature: 6.0°C
Voltage: 14.60 V
RPM: 800 /min
Load: 0.0 %
Load: 11.0 %
Address 09: Cent. Elect. Labels: 8P0-907-279-23-B.lbl
Part No SW: 8P0 907 279 HW: 8P0 907 279 *
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000370227
Coding: 008C4F00A0141000000000000000000000
VCID: 7AFC5333356F61EE25-802E
Subsystem 1 - Part No: 8P2 955 119 A Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
3 Faults Found:
01259 - Fuel Pump Relay (J17)
01506 - Bulb for Rear Fog; Right (L47)
012 - Electrical Fault in Circuit
00526 - Brake Light Switch (F)
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0130
Coding: 0011602
VCID: 4382EED70225E02636-8016
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
VCID: 6FEA72677E2D344682-803A
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 950 G HW: 8P0 920 950 G
Component: KOMBIINSTR. VDO H27 0110
Revision: D08 Serial number: 1240DD08001662
Coding: 0004403
Shop #: WSC 00681 210 61343
VCID: 3878893B4BE3B3FE93-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103C13B60F
Coding: 3D0F0342070101
VCID: 264457439157350E31-8072
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D08 Serial number: AUX7Z0D0FNK036
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 397E8C3F70E9AAF66C-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.9 1202
VCID: 2E54AF63B9A77D4EC9-807A
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
Shop #: WSC 01357 011 00200
VCID: 79FE4C3F30696AF62C-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
2 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
00849 - S-contact at Ignition/Starter Switch (D)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001092044
VCID: 70E8711B63132BBE9B-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H51 0060
Revision: 05S Serial number: AUZ2Z3C1160277
Coding: 0001001
Shop #: WSC 00359 210 53633
5 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 5
Reset counter: 92
Time Indication: 15
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 92
Time Indication: 15
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 90
Mileage: 223410 km
Time Indication: 0
Date: 2015.06.10
Time: 22:18:49
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 93
Mileage: 224236 km
Time Indication: 0
Date: 2015.07.02
Time: 15:22:57
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 53
Mileage: 222969 km
Time Indication: 0
Date: 2015.06.04
Time: 14:01:58
End-------------------------(Elapsed Time: 01:34)--------------------------
Was wondering could it be anything to do with the brake switch I know they play hell on vw/audi grateful for all help
www.Ross-Tech.com
Coding: 0000071
4 Faults Found:
Freeze Frame:
RPM: 0 /min
Load: 15.3 %
Load: 11.4 %
RPM: 0 /min
Load: 15.3 %
Load: 11.0 %
Freeze Frame:
RPM: 896 /min
Bin. Bits: 00000100
RPM: 640 /min
Bin. Bits: 00000100
Freeze Frame:
RPM: 0 /min
Load: 15.3 %
Load: 11.4 %
RPM: 0 /min
Load: 15.3 %
Load: 11.0 %
Freeze Frame:
RPM: 288 /min
Bin. Bits: 00000010
Temperature: 67.5°C
Coding: 0019077
1 Fault Found:
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 92
Mileage: 221556 km
Time Indication: 0
Date: 2015.04.27
Time: 20:46:31
Freeze Frame:
Voltage: 13.50 V
Temperature: 8.5°C
(no units): 165.0
(no units): 35.0
Temperature: 8.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 64
Mileage: 222082 km
Time Indication: 0
Date: 2015.05.12
Time: 15:12:57
Freeze Frame:
Temperature: 17.5°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 91
Mileage: 222727 km
Time Indication: 0
Date: 2015.05.27
Time: 21:22:12
Freeze Frame:
Voltage: 12.20 V
Temperature: 15.5°C
(no units): 232.0
(no units): 229.0
Temperature: 10.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 65
Mileage: 222089 km
Time Indication: 0
Date: 2015.05.12
Time: 17:23:26
Freeze Frame:
Temperature: 14.5°C
Freeze Frame:
Fault Priority: 3
Reset counter: 93
Mileage: 211664 km
Time Indication: 0
Date: 2014.08.13
Time: 11:18:22
Freeze Frame:
Temperature: 6.0°C
Voltage: 14.60 V
RPM: 800 /min
Load: 0.0 %
Load: 11.0 %
Coding: 16711696
Shop #: WSC 00000
3 Faults Found:
Coding: 0011602
Coding: 0000002
Coding: 0004403
Coding: 0000048
2 Faults Found:
Coding: 0000048
Coding: 0001001
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 92
Time Indication: 15
Freeze Frame:
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 92
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 90
Mileage: 223410 km
Time Indication: 0
Date: 2015.06.10
Time: 22:18:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 93
Mileage: 224236 km
Time Indication: 0
Date: 2015.07.02
Time: 15:22:57
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 53
Mileage: 222969 km
Time Indication: 0
Date: 2015.06.04
Time: 14:01:58
