Help Please Engine undertray fasteners - A4 Avant 3.0 TDI SE
mrming Jun 11, 2018
  1. mrming
    mrming New Member
    17
    Hi all,
    Our B8 A4 Avant's engine undertray has lost a fastener and is hanging down on the driver’s side.
    The drivers side with the fastener missing looks like this:
    The passenger side which still has a fastener looks like this:
    And the front of the car looks like this:
    I've found this pack of fasteners on eBay.
    Can anyone tell me if they're right? If not any pointers on where to get the correct ones would be much appreciated. Am driving it to the South of France next Monday and want to be sure it doesn't fall off!
  2. Avatar
    Google AdSense Advertisement
  3. GAS MONKEY
    GAS MONKEY Blood Sweat & Beers Team Ibis saloon TDi Audi A4 Black Edition S-line owners group
    813
    436
    They look expensive as you onely need one stick a cable tie in it in till you get one on that image it's the middle one's you need but who knows on size ECT
  4. mrming
    mrming New Member
    17
    Okay thanks – yep I could feed a cable tie through the hole visible in the second pic above.
    Do you happen to know what these parts are called? Is it the skid pan? And if so is it a speed nut and dowel pin?
  5. tech838
    tech838 New Member
    29
    10
    Its cheap enough to do it properly. You can get the pin and spring clip as a pair from the dealers / TPS for about £3.
    Or try the parts request on here
    I don't know if we can post links but also just type "Engine Cover Undertray Fitting Clip Kit Metal Screw Audi" into eBay
  6. feva
    feva Well-Known Member
    843
    453
    Sure its the same as one I've just replaced, from dealers 48p each
    Sent from my Note 8 using Tapatalk
  7. Mario
    Mario Active Member TDi Audi A4 quattro S-line owners group S tronic Manual
    469
    179
    43
    Dealer will sell them cheap enough to be honest, or just cable tie like I did on my B7 A4. Either will do the job.
    If you need to know the size you can always take out the one from the other side, measure it up and order one that looks similar from eBay that has the same dimensions.
    They are just 1/4 turn fasteners (sometimes known as DZus fasteners) and almost everyone sells them.
