Engine start system fault
KINGHORN Apr 25, 2019
  1. KINGHORN
    KINGHORN New Member
    12
    hello hope someone can help
    I have a 2013 a3 1.8tfsi dsg and a fault staying engine start system fault has popped up on the dash
    Diagnostics is picking up code B200096
    I can’t find any info on this anywhere
  2. Avatar
    Google AdSense Advertisement
  3. Tashfeen
    Tashfeen Moderator Staff Member Moderator Team Glacier Supercharged TFSI Owners Group Team V6 VCDS Map User Team Scuba Audi S4 Audi A3 Black Edition quattro
    6,429
    13,217
    Do you meant Start/Stop system?
  4. KINGHORN
    KINGHORN New Member
    12
    Nope engine start system it says
  5. KINGHORN
    KINGHORN New Member
    12
    Start stop works fine. When the engine is running I can turn ignition all the way off and the engine remains running. Only stops when I pull the key out
  6. JohnM100
    JohnM100 Well-Known Member Gold Supporter VCDS Map User Team Navarra Audi S3 Black Edition
    1,093
    520
    I don’t know that code but seems like an issue with the ignition key barrel.
    Sent from my iPad using Tapatalk Pro
    Tashfeen likes this.
  7. Tashfeen
    6,429
    13,217
    +1 ignition switch or power relay if there are no other symptoms, i.e. dieseling.
  8. KINGHORN
    KINGHORN New Member
    12
    I switched the relays and nothing changed
    Dieseling?
  9. NHN
    30,376
    1,986
    Ignition switch.
    Tashfeen and Khufu like this.
  10. Khufu
    Khufu Well-Known Member
    5,977
    146
    I agree. Contacts on switch must be worn/shorting if you can switch off and car still runs. I've heard of diesels running on when you switch off car as they run off the engine oil but stalling car is only way to stop that.​
    NHN likes this.
  11. NHN
    30,376
    1,986
    Hey bud, nice to see you around.
    Yeah the imf has a play on the run on iirc.
  12. Avatar
  13. KINGHORN
    KINGHORN New Member
    12
    Ok cheers il look at getting one. Anyone know how to change it?
  14. AlS3BE
    AlS3BE Well-Known Member
    2,265
    1,220
    Was there not a massive recall on ignition barrels on vag cars a while back? I can remember I had one on my wife’s golf a few years back.
    Might be worth checking if your car has outstanding recalls.
  15. Ccfc92
    Ccfc92 New Member
    I have the same issue with my A3 13MY any ideas what it is??
  16. JohnM100
    1,093
    520
    Same as posts #5, #6, #8 and #9
  17. Ccfc92
    Ccfc92 New Member
    I can’t see anywhere that people have said what the issue actually was and sorted the problem
  18. JohnM100
    1,093
    520
    Admittedly the posts don’t say how to fix, but from all respondents they are all consistent in their message as to likely area of failure and hence focus for further investigation
    Welcome to the forum BTW.
  19. Ccfc92
    Ccfc92 New Member
    Yeah I see where they were coming from. Problem started around 10 days ago. I went to my local mechanic he said possibly ignition cap. I wasn’t sure what he meant by that but I emailed Audi last week and they gave me a price for this but when I explained the problem to them ie the key not cutting the engine off when in position 0. They said it’s more that likely the ignition switch which was a lot cheaper than the initial ignition cap. They advise to put on diag machine to tell you your fault codes. But I have already has this done with my local mechanic which made him say ignition cap. Think im going to go ahead get the switch changed see if it solves the matter.
    Thankyou.
