Engine sound
swimboy Aug 9, 2019
  1. swimboy
    swimboy New Member
    Hi all, just bought an S4 and love it so far (2 days) but curious about the engine sound. Can I upload a video from my phone on here for people to see&hear? Thank you
  2. Avatar
    Google AdSense Advertisement
  3. rum4mo
    rum4mo Well-Known Member
    1,953
    469
    If you are meaning the rough/harsh mechanical noises, it really depends on which engine type you had previously.
    I used to own a VW Passat 2.8V6 30V 4Motion and that version of the Audi engine was extremely quiet and smooth at idle - maybe a bit noisy at initial cold start due to chain tensioners taking a bit of time to get sorted out - but only now and again. This 2011 S4 bought at 12.5K miles and now only at 25K miles has always sounded rougher than that older engine.
    I started a thread on my engine sounding like there was something light weight and tinny making noises - but I only noticed that after completing an oil change, I never ever lift the bonnet just to check what noises the engine makes at idle when cold or hot - in future I'll do that now and again and definitely just before carrying out an oil change so that I can compare before/after noises. Obviously after an oil change you do look closely under the bonnet and underneath to check that there are no oil leaks.
    I left that car unused until I bought another oil filter, just in case I had left something, ie a cloth, in the oil filter base to soak up oil - and had forgotten it, when I removed the just fitted filter I found nothing, so just cleaned up the oil filter case, replaced the O-rings again, and started the engine - no tinny noises! So either the previous filter was duff, which I have no reason to believe (Mann so exactly the same as an Audi sourced one), or I went looking for problems that did not exist after initial start up after changing the oil. I'll leave updating the thread I started until some time/miles have passed.
  4. swimboy
    swimboy New Member
    Ah sorry - it’s a 2013 B8.5. Is there any way of uploading a video on here from my phone please so then it would be easier to hear? Thanks for your reply :)
  5. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    3,768
    2,740
    You'll need to stick it on YouTube and post the link here. Should be able to upload it as unlisted so it won't be found in searches.
    swimboy likes this.
  6. swimboy
    swimboy New Member
    Thank you - please see attached video!
  7. deanshaw24
    deanshaw24 Well-Known Member VCDS Map User
    1,006
    720
    That sounds fine to me
  8. swimboy
    swimboy New Member
    Phew..! I didn’t know if it was meant to be super smooth, it just sounds a bit ‘tappy / clicky” and was worried. I appreciate your feedback
    deanshaw24 likes this.
  9. deanshaw24
    1,006
    720
    Yeah my one sounds exactly the same as that. A lot quieter when the bonnet is shut. Obviously just a noisy engine
  10. swimboy
    swimboy New Member
    Cool. Yeah it’s quiter with the bonnet shut but could still hear it and was worried but thanks for your comment
  11. rum4mo
    1,953
    469
    Exactly the same as mine!
    Generally speaking, all newer VW Group engines sound louder/rougher than VW Group engines from the past, its called progress!(?)
  12. Avatar
  13. swimboy
    swimboy New Member
    Good good! Touch wood then, all ok..! I asked on another forum too and others have also confirmed what you guys have said - I was just so worried! Also, the idle vibration whilst stationary - apparently that’s normal too? Otherwise though, I’m SO please with the car!
  14. Dippy
    Dippy Well-Known Member Team Monsoon Audi S5 Black Edition
    1,785
    1,256
    It's a 90 degree V6 so that's just about the worst vibrating engine possible.
    I agree on the video - sounds normal. Don't forget it has chain driven quad camshafts driving 24 valves, so that's a lot of metal on metal action which sounds worst at idle.
  15. swimboy
    swimboy New Member
    That’s a good point, yes when I think about it like that - it is a lot of metal on metal action! Hopefull I can relax and continue to enjoy the beast. I really appreciate everyone’s comments - it’s saved a lot of worry!
  16. rum4mo
    1,953
    469
    Well the old 2.8V6 was a 30V and again 90 degree V, and it was a lot quieter than this 3.0TSI 24V, as I said "progress", maybe "why fit good sound proofing if it is not necessary, sod it just don't bother to make these engines quiet".
  17. jdp1962
    jdp1962 Grumpy Old Man TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 Black Edition quattro S tronic
    9,371
    3,989
    I'm guessing you've never driven a Ford Capri or Corsair fitted with a 2-litre V4.
  18. Dippy
    1,785
    1,256
    My B5 S4 had the 2.7 version of the 30V 90 degree V6 and I can't agree that it was quieter.
    I didn't know that Ford made V4 engines - my Capris had either the 4 in-line or the V6. I'm not sure of the point of a V4 as those cars had plenty of space in the engine bay. I'd still suggest that a 90 degree V6 vibrates more than a 90 degree V4.
  19. jdp1962
    9,371
    3,989
    Nothing vibrates more than a V4. It is probably the roughest, and most inherently unbalanced of any engine configuration. There are sound technical reasons for this; I've no idea what they are because I didn't take even O-level Physics (that's GCSE for post baby boomers :) ).
    rabhrab likes this.
  20. Rugslasher
    Rugslasher New Member
    25
    10
    Was wondering about my rs4 B8 being very noisy on cold start (rattles) for about 10 seconds then smooth as anything, is this normal for the v8 ?
