Engine Shake on Idle
Toby Ash Jul 11, 2018
  1. Toby Ash
    Toby Ash New Member
    12
    Hi All
    I have a Audi 2.0TDi B7 Cabrio with the BPW engine
    On idle it shakes for about 10-15 seconds after which it smooths out, it also shakes when quickly going from cruising speed to idle (Roadworks etc.), again after about 15 seconds it smooths out
    I have replaced injector one because it had a high injection value (Over -2.8), this did not solve the issue, injectors have been adjusted and shaking is better when hot but it still shakes
    Engine mounts are fine, mine have sensor but no faults and no liquid leakage
    Dual Mass has been changed, when in or out of gear it makes no difference
    Does anybody have any ideas what to check now?
    All help is much appreciated :icon thumright:
  2. Avatar
    Google AdSense Advertisement
  3. OliNix
    OliNix Active Member
    244
    78
    Have you checked the snub mount? (Mount on front of engine)
    It is a foam/rubber mount that easily perishes.
  4. Toby Ash
    Toby Ash New Member
    12
    Thanks OilNix
    I have and it's slightly perished, the only thing is that the engine rocks side to side but this mount is forward facing isn't it?
  5. OliNix
    244
    78
    It is, but when you accelerate it’s what stops the Powertrain lurching backwards and forwards.
  6. Toby Ash
    Toby Ash New Member
    12
    Ok, when driving it's not noticeable, only when idle, it's strange
  7. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,033
    325
    Is it on the first cold start of the day or on every fresh day during the day? Is it slightly worse in colder weather?
  8. Toby Ash
    Toby Ash New Member
    12
    It's everytime it's started, hot or cold, for about 15 seconds then it smooths out and stops, but comes back if sitting at traffic lights etc
  9. Toby Ash
    Toby Ash New Member
    12
    I have noticed at 1500RPM it rocks/shakes constantly, but at 2000rpm it's smooth
  10. OliNix
    244
    78
    I would also check compression on all cylinders. It sounds like typical misfire symptoms. Should flag a DTC, but if it’s minor it may not.
    Check compression and also injectors.
