Engine problem
kambi29
Haskovo
Hello guys, my A3 engine is having some issues...It is 1.6 TDI 2010 CR. Today I was making smth in the garage on the front grill and after that I took the car out and let it run for a while in one position, after 3, 4 mins engine stopped itself. I tried to start it, it did start for a sec and immediatly stopped again...tried it at least 10 times, the result was the same, i connect vcds and it showed fuel rail pressure low. After i cleared the errors i tried to start and a few times and no result. I let it sit for 3-4 mins and tried again and started without any issue... i let it sit again until 90 deg C. And tonight i wanted to make a round and it did that **** again, but now i wasnt able to start ti for more than 2 sec. And there was no error messages on vcds...what should i check?
