And juddering when driving. I know this is not a happy sign but anyone have possible ideas? Would you only take to audi house or will local garage be sufficient you reckon, a 2008 1.8t a4.
Had root around and sounds suspiciously like coil pack problem. Anyone local with vcds who could run a scan, obv beer tokens will be available ? North Manchester/Oldham/Rochdale
heers fella, just found the vcds map and msg a chap fairly close by. I had coil pack go few month ago in a saab 9-3 and cost me circa 200 notes, bit of a regular occurrence
Cheers phil. Have asked a couple of local chaps on vcds map for a scan so if no joy ill go down the old detective route and use your process of elimination method .
