  2. Dismiss Notice
Enable Battery Meter on MMI
mpc Dec 10, 2015
  1. mpc
    mpc Member
    118
    Is it possible to enable the battery meter on my MMI without using a VCDS? I have an A4 B8 Avant S-Line.
  2. Avatar
    snack-media
    Advertisement
  3. Darren92
    Darren92 Well-Known Member
    2,465
    649
    You need VCDS to enable the hidden menu, which system is fitted as there is no function for 3G+.
  4. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User
    7,263
    3,608
    I think You can do it with carista which is an app on your mobile and a £5 Bluetooth dangle. Have a search on the forum for carista
  5. Stonefish
    Stonefish Active Member
    241
    64
    There is a script that runs on an SD card called greenmenu_on.zip. Do a google search and it should provide you with the info on how to use it etc. I've used it on an MMI 3G+ unit. Should work on a MMI 3G.
  6. jdp1962
    jdp1962 Grumpy Old Man Gold Supporter
    9,609
    4,226
    My hidden menu is enabled. Does that mean I can activate the battery meter from there? If so, what's the sequence?
  7. Dippy
    Dippy Well-Known Member
    1,920
    1,316
    I didn't think that the battery meter is possible on the B8.5 Jeff, so if you manage to get yours to work I'd been keen to know about it.
  8. jdp1962
    9,609
    4,226
    Dang!
  9. GeoffDunk
    GeoffDunk Well-Known Member
    1,300
    398
    B8 yes you could have enabled the battery meter with the green (service) menu.
    B8.5 Battery meter no longer available.
  10. B5NUT
    B5NUT Well-Known Member VCDS Map User
    5,012
    1,218
    It was removed on all MMI 3GP systems, as Audi realised their battery monitor system was rubbish! It was hopeless on the 2G system and they made no improvement on the 3G system, so canned it on 3GP.
  11. HertS3
    HertS3 Well-Known Member
    918
    306
    Damn, enabled on green menu but didn't show up :( anyone with B8.5 manage to do this?
  12. Avatar
    snack-media
    Advertisement
  13. S3 TAM
    S3 TAM Pocket now empty
    635
    19
  14. HertS3
    918
    306
    Indeed, tried all that but won't show up :/
  15. Dippy
    1,920
    1,316
    Battery meter is not an option on B8.5
  16. PostieStew
    PostieStew Member
    53
    9
    I have a b8 2009 but have had 3G plus from a a5 retrofitted, does this mean I won’t be able to get this as I did have it on my old system.
  17. HertS3
    918
    306
    Sounds like it...
  18. PostieStew
    PostieStew Member
    53
    9
    Shame as it was quite handy.
