Hoping someone can help!
I'm having a problem with the electronic parking brake on the right rear not working and getting a electronic parking brake malfunction on the dash.
Initially, thought it was the parking brake motor so changed that but still not working. Tested the original motor on a 12v battery (should have done this first) and that it works fine. Checked the voltage at the plug and wasn't getting anything when engaging/releasing the handbrake. So changed the module and still nothing from the right side.
Finally managed to get it scanned with vcds and got the following:
Address 53: Parking Brake Labels: 8K0-907-801-V1.clb
1 Fault Found:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
007 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 1
Fault Frequency: 1
Reset counter: 58
Mileage: 166275 km
Time Indication: 0
Date: 2009.11.08
Time: 15:28:46
Freeze Frame:
Voltage: 11.50 V
Count: 33
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1004
I guessing this means there might be a split in a wire somewhere? Couldn't see anything exposed wires around the module, but I guess it could be somewhere else. The module looks to have two 12v feeds into it (guessing one for left motor and one for right motor). Both are giving the same voltage.
Also got the following when doing advanced measurements (with handbrake engaged):
Info1 - Info2 - Actual
Battery Voltage - (Terminal 30) - 11.50V
Shut-Off Current - Left (Calculated) - 17.100A
Shut-Off Current - Right (Calculated) - ERROR
Does anyone have a wiring diagram for the module to help trace the wires?
Any help/pointers would be massively appreciated.
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 58
Mileage: 166275 km
Time Indication: 0
Date: 2009.11.08
Time: 15:28:46
Freeze Frame:
Voltage: 11.50 V
Count: 33
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1004
