Electronic Parking Brake Issues
S3Steve
Peterborough
I have a fault with my EPB. I was doing a rear pad and disk change on my 2010 A6 following the guide on the rosstech website. As i began and set the caliper to open on VCDS my dashboard displayed a parking brake fault, is this normal? Not knowing and with the parking brake now released i continued and changed the disks and pads. I continued on with the procedure by closing the EPB and then carrying out the function test all ok. (I had battery charger hooked up throughout). I am still displaying parking brake fault on the dash and the parking brake is now not working,the light on the switch just flashes when i try to operate it. The EPB functions when controlled by VCDS. Any ideas?
I do have a broken wheel speed sensor that I found/broke while changing the disks could this be the cause?On my way out in a minute to go pick a new one up?
VCDS print out below
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
Ross-Tech: Home
VIN: WAUZZZ4F8AN045799 License Plate: VN59UHO
Mileage: 193380km-120160mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 08 09 0E 15 16 17 19 36 42 46 4F 52 53 55 56 5F 62
72 76
VIN: WAUZZZ4F8AN045799 Mileage: 193380km-120160miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 019 AG HW: 03L 906 022 FG
Component: R4 2.0l TDI H03 9978
Revision: 11H03--- Serial number:
Coding: 010D002C18072118
Shop #: WSC 10756 002 1048576
ASAM Dataset: EV_ECM20TDI03L906019AG A01006
ROD: EV_ECM20TDI03L906019AG.rod
VCID: 70E46E9FABA293C119-8024
1 Fault Found:
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 4
Mileage: 193389 km
Date: 2017.04.27
Time: 12:35:06
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 8 °C
Intake air temperature: 10 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.220 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Accelerator position: 0.00 %
Cruise Control System: specified speed: 0.00 km/h
Cr Ctl st Sh Off Irv Lst-Bit 0: 11111111
Cr Ctl st Sh Off Rv Lst-Bit 0: 11111111
Cruise Control System (CCS): switch position-Bit 0: 10000001
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
Component: ESP8 front H03 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0020859
Shop #: WSC 02325 785 00200
VCID: 6DDA77EB74907E2932-8038
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 193389 km
Time Indication: 0
Date: 2017.04.27
Time: 12:56:40
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0382
Hex Value: 0x0008
Hex Value: 0xB194
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501454421
Coding: 0000145
Shop #: WSC 02324 785 00200
VCID: 254A4FCBECE08669BA-8070
Subsystem 1 - Part No: 4F0 910 132 F
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0054
No fault code found.
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000074 Serial number: 00000030491522
Coding: 0001300
VCID: 1D3A672BC4B04EA9E2-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0113121
Shop #: WSC 02335 785 00200
VCID: 336EA1935234E8D924-8066
Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 152A7F0BFC8016E92A-8040
Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003F9001WWAG
Coding: 30314236303630303033554A305234463053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 356A9F8B9440F6E90A-8060
Crash sensor for side airbag: driver side:
Serial number: 3574SRB40000A1AC91BE
Crash sensor for side airbag: front passenger side:
Serial number: 3584SRB40000A1A8E9BO
Crash sensor for side airbag: rear: driver side:
Serial number: 3516HRB402T9LBCH03QW
Crash sensor for side airbag: rear: passenger side:
Serial number: 3526HRB402J9KI9J5CGW
Crash sensor for front airbag: driver side:
Serial number: 3554NRB4000052BC6751
Crash sensor for front airbag: front passenger side:
Serial number: 3564NRB4000052B0829Y
1 Fault Found:
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90055093240219
Coding: 0112042
VCID: 275645C396EC947988-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 G HW: 4F0 920 983 G
Component: KOMBIINSTR. H08 0144
Revision: 00100000 Serial number: CN3035JC9
Coding: 2F75100502002600010400
Shop #: WSC 02391 823 56573
VCID: 3064AE9F6322D3C159-8064
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 188542 km
Time Indication: 0
Date: 2017.02.24
Time: 12:14:33
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0035
Revision: LB100029 Serial number: 2900L09B080069
Coding: 000B03
VCID: 397293BBB0581289EE-806C
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0125
Serial number: 00000000002790809725
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001010034599
Coding: 00781300004011110000
VCID: 3162AB9B6828DAC956-8064
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000102374060
Coding: 011F06205E41410001
VCID: 4688E847F1A66D7193-8012
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H29 0250
Revision: 02500029 Serial number: 01242876580000
Coding: 0140019
VCID: 356A9F8B5C40F6E90A-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000673389
Coding: 0001104
VCID: 5EB82027893615B1BB-800A
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000102392531
VCID: 458AEF4BCCA066699A-8010
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000111
Shop #: WSC 02145 785 00200
VCID: 21425BDBF8C86A49C6-8074
1 Fault Found:
01316 - ABS Control Module
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 145
Mileage: 193384 km
Time Indication: 0
Date: 2017.04.27
Time: 12:35:06
Freeze Frame:
Voltage: 11.28 V
Count: 231
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3F86FDA36E7C3CB9D0-806A
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H45 0020
Revision: AB001007 Serial number: 342K-097731086
Coding: 010003020100000000
VCID: 1F465D230EBC5CB9F0-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 652 A HW: 4E0 035 652
Component: B-BN-EU H52 0048
Revision: -------- Serial number: 349K6097526774
Coding: 010101010102C3ED41000705EF6300030001
Subsystem 1 - Part No: 4G0 919 884 F
Component: EUR 2010 1005
Subsystem 2 - Part No SW: 4L0 919 604 HW: 4L0 919 604
Component: DU6 Basic H43 0306
Serial number: 9355KT091052454
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
Component: Bedienteil MM H01 0060
Serial number: 00000001452693
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000102389893
Coding: 010E04204041220001
VCID: 438EF153C2945859B4-8016
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000102389756
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H02 0500
Revision: 00H02000 Serial number: 12630932702539
Coding: 0200016
VCID: 2A50BCF785FEA91197-807E
End-------------------------(Elapsed Time: 02:52)--------------------------
Any help would be much appreciated.
I replaced the sensor and the EPB worked fine. Just had an ESP fault left. That just needed the ESP function test doing.
With all the horror stories around I was concerned earlier I may have fried the control module.
