So I was driving home this afternoon, having done 18 miles of the journey, with 2 to go. The car just died as I was driving, the side lights were on so I had dash illumination, The Radio, ALL the dash including clock needles died, the car shut off, I lost lights, indicators. I pulled over with no power steering (thats when I discovered the indicators didn't work) .The hazards worked , coasted over to the side of the road , the car engine was off and was in gear(6th) All that was lit was the hazard switch and the auto lights on the air con display. So I turned off the ignition, took the key out, re-inserted and the car started straight away.
Didn't check for faults with VAG-COM, will do this tomorrow , But WTF happedned ?
It has been suggested that it could be a loose main power lead to the main fuse box, does the hazard switch use a different feed ? Whats the order of things I should check ?
BTW, 1.9TDi Engine.
BTW, 1.9TDi Engine.
