Egr cooler delete
Jason owen
has any one done the egr cooler delete on 2.0tdi 140?
Done egr delete and remap last year, 3daysnlater my turbo **** its self somreplaced that along oil filter etc, then flywheel started vibrating somdone the clutch 7das after the turbo
Few months later now i have alot of smoke on cold start up, and seem to be using alot of water quicker then normall, 'egr cooler '
So i want to just remove it as its not needed anyway now,
Just wanering if anyone has any info on doing this?
Reactions: Jason owen
yeh mate, i have my egr off the car, all you need to do when taking the full thing out is connect the cooling water inlet and outlet together so that it loops back on its self dead easy i used a 180 pipe to do mine
just the same as yours Carl really but mines a shiny ally pipe dont forget the blacking plates too lol
yeh i could only get an ally one at the time mate
Reactions: carlcall
What size pipe would i need?
Iv got a blanking plate already
19mm IIRC Jason.
I used a piece of rubber hose with a 90 degree bend in it, a 19mm straight coupler and a 90 degree coupler.
And Tony used a 180 degree pipe.
All available off eBay.
19mm IIRC Jason.
So the inside diameter of the pipe is 19mm on both ?.
Yes pal.
I forgot to mention that once the engine cover is back in place you can't see the plumbing!
and yes Carl i was lazy and left the pipe work at the rear of the engine lmao
I can only find 180 19mm alloy pioe with leg lentgh of 150mm think thats long enough?.
Yes I would say so Jason.
I'm surprised you've not lost that gasket also Tony......but that pipe was a real PITA to remove.
Reactions: tony mc
I broke the temp sensor when inremoved it and didnt notice till got home for the unit and had no water haha doh!!
Ill order te pipe now
Thanks for thenhelp
Reactions: tony mc and carlcall
why you think i left it lol, never noticed the gasket ha ha,
@Jason yeh mate i cut it down so they were level with each other, the egr will never go back on so....
I'm wanting to do a egr delete on my 1.9tdi just wanting to know what kit I would need as when I go on eBay and look it comes up with loads.
What pipe did you order @Jason owen ? Been thinking about doing mine as I've already the EGR blanked off and mapped out, if i'm right in saying i'll need another blanking plate to blank off the hole that normally goes into the cooler?
Brilliant I'll have a butchers at my egr when I can. May even drop darkside developments a message see if they do the right kit
aarron it depends on your engine code.. i have a 1.9 tdi (BKE) and none of the ones given would fit mine, nor do darkside do a kit that fits .. i ordered mine from the US
Yeah I'm sure mines a bke as well. Do you have a link for the one that you brought ?
I know they both do the same job but much rather spend more and get the decent forge one
yeah those are the ones .. i got the cheaper yank one and had no problems whatsoever, infact, the cheaper one even comes with the elbow fitting to loop your egr cooler hose whereas the forge one doesnt
Reactions: carlcall
At the end of the day it's all down to personal choice and how quickly you want it.....if like myself and several others that are too impatient to wait for it from the states it would have to be the forge one.
Ahh well at least I now know which one to get. Cheers lads
Hi mate i just ebayed 180 alloy pipe
Plenty on there. I got one with 19mm outside diameter, was £8-9 delivered waiting for it to arrive now. Can let you know how imget on once its fitted, also ordered an egr plank plate £3.99
Yeah that would be great, also what blanking was it as I know there's different sizes? You can recall the size at all?
Good day peeps
I have a 2007 2.0 TDI (BRD engine) and am also in the process of doing an EGR delete. I'm trying to keep things as stock standard as possible for the time being, so I'm only planning on installing the blanking plates and doing the EGR delete in software. My question is, referring to the picture, should I blank it off at A (exit of EGR cooler) or B (inlet of EGR cooler, this is my preferred choice). And if I blank it off at B, what influence does it have on C? I know it is part of the vacuum system, but can anyone tell me what exactly is it's purpose?
Regards
Good day peeps
Regards
Can I ask why you're not removing your cooler completely?
It's a faff to do (because of 1 bolt), but it simplifies things no end.
Sorry I can't help with your blanking plates, as I removed the egr valve , cooler and changed my manifold to a flapless one, removing the vacuum lines too.
15
773
