Steve Barnes
Hi all, just after some advice. I've been looking at a car (2006, 2.0l diesel) for a friend today which has had a diagnoses of ECU failure, however the car runs flawlessly despite it having engine management light, ABS and coolant temp lights on when I inspected it.
I used a scanner to look for codes which cleared the lights, but gave the following..
Is there anywhere I should be looking or tests I can do to find where the fault lies?
I am thinking there maybe a bad ground or cable break somewhere as opposed to ECU failure given everything is working as it should.
Car Scanner ELM OBD2
DTC report
Selected brand: Audi
============1==============
P2100
Raw code: 2100
ECU: OBD-II
Status: Confirmed
OBDII: Throttle actuator control (TAC) motor - open circuit
============2==============
P0117
Raw code: 0117
ECU: OBD-II
Status: Confirmed
OBDII: Engine coolant temperature (ECT) sensor - low input
Audi: Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
============3==============
P2102
Raw code: 2102
ECU: OBD-II
Status: Confirmed
OBDII: Throttle actuator control (TAC) motor - circuit low
============4==============
0470
Raw code: 01D6
ECU: 19. CAN Gateway
Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: Common concern data bus Comfort in single-wire data transfer mode; Group data bus convenience in a single wire
============5==============
0290
Raw code: 0122
ECU: 03. ABS control unit
Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory
Audi: Rear Left Wheel Speed Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small
============6==============
1435
Raw code: 059B
Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: Brake Pressure Sensor 1-G201; Brake pressure sender 1-G201
============7==============
19557
Raw code: 4C65
ECU: 01. Engine control unit
Status: Validated and stored in non volatile memory, Validated fault present at time of request
Audi: P3101 Intake manifold flap actuator motor-V157: open circuit / short to ground; Intake manifold flap motor-V157 Open circuit / short circuit to earth
============8==============
17075
Raw code: 42B3
Audi: P0691 Radiator Fan Control 1: Short to Ground; Cooling fan control 1 short circuit to ground
============9==============
16501
Raw code: 4075
ECU: 01. Engine control unit[Archive (inactive)]
Audi: P0117 Coolant Temperature Sensor-G62: Signal Too Low; Coolant temperature sender G62 signal too small
============10==============
19558
Raw code: 4C66
Audi: P3102 Intake manifold flap actuator motor-V157: no signal; Intake manifold flap motor-V157 no signal
============11==============
17056
Raw code: 42A0
Status: Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: P0672 Glow plug for cylinder 2-Q11: electrical failure; Glow plug cylinder 2-Q11 electrical fault in the circuit
============12==============
17057
Raw code: 42A1
Audi: P0673 Glow plug 3-Q12: malfunction in an electric chain; Glow plug cylinder 3-Q12 electrical fault in the circuit
============13==============
17058
Raw code: 42A2
Audi: P0674 4-Q13 glow plug, electrical failure; Glow plug cylinder 4-Q13 electrical fault in the circuit
============14==============
0483
Raw code: 01E3
ECU: 08. Heater and climate
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: Auxiliary air heater control unit; Control unit for additional air heating
============15==============
16346
Raw code: 3FDA
ECU: 17. Dashboard
Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: Control block; Control unit
============16==============
0932
Raw code: 03A4
ECU: 42. Driver door electronic equipment
Status: Pending fault present, Test conditions are met, Validated and stored in non volatile memory
Audi: Driver Side Power Window Motor-V147; Motor window regulator driver's side-V147
============17==============
0361
Raw code: 0169
ECU: 7D. Additional heater (VW TP2.0)
Audi: Heater, auxiliary heater-Z35; Heating element for additional heating-Z35; Bank1, fuel metering system 2 malfunction
============18==============
P2102
Raw code: 2102
ECU: OBD-II
Status: Pending
============19==============
P2100
Raw code: 2100
ECU: OBD-II
Status: Pending
============20==============
0470
Raw code: 01D6
============21==============
1435
Raw code: 059B
============22==============
19558
Raw code: 4C66
============23==============
19557
Raw code: 4C65
Status: Validated fault present at time of request
============24==============
17075
Raw code: 42B3
============25==============
0483
Raw code: 01E3
============26==============
16346
Raw code: 3FDA
ECU: 17. Dashboard
============27==============
0932
Raw code: 03A4
DTC report
P2100
Raw code: 2100
ECU: OBD-II
Status: Confirmed
P0117
Raw code: 0117
ECU: OBD-II
Status: Confirmed
P2102
Raw code: 2102
ECU: OBD-II
Status: Confirmed
0470
Raw code: 01D6
0290
Raw code: 0122
1435
Raw code: 059B
19557
Raw code: 4C65
17075
Raw code: 42B3
16501
Raw code: 4075
19558
Raw code: 4C66
17056
Raw code: 42A0
17057
Raw code: 42A1
17058
Raw code: 42A2
0483
Raw code: 01E3
16346
Raw code: 3FDA
ECU: 17. Dashboard
0932
Raw code: 03A4
0361
Raw code: 0169
P2102
Raw code: 2102
ECU: OBD-II
Status: Pending
P2100
Raw code: 2100
ECU: OBD-II
Status: Pending
0470
Raw code: 01D6
1435
Raw code: 059B
19558
Raw code: 4C66
19557
Raw code: 4C65
17075
Raw code: 42B3
0483
Raw code: 01E3
16346
Raw code: 3FDA
ECU: 17. Dashboard
0932
Raw code: 03A4
