  2. Dismiss Notice
Facelift Dyno Spectrum DS1.
T-1000 Nov 27, 2020
  1. T-1000
    T-1000 Registered User
    1,172
    1,111
    This arrived earlier this week.
  2. Avatar
    snack-media
    Advertisement
  3. Bonstio
    Bonstio Registered User
    117
    45
    And? Any use? Good value?
    Sent from my SM-F916B using Tapatalk
  4. T-1000
    1,172
    1,111
    First impressions.....
    Very impressive piece of kit.
    Variety of OTS maps from stage 1-4
    Uses TunerPro to make tweaks etc to maps.
    Different octanes / Flex fuel / Ethanol supported.
    Switchable maps via cruise control and you can program the torque / power gauges to show other parameters.
    You can emulate changes with it before flashing to the ECU.
  5. terminator x
    terminator x Registered User
    4,736
    5,407
    What about your warranty though Sean ;)
    TX.
    T-1000 likes this.
  6. T-1000
    1,172
    1,111
    Lol what warranty John cars 3 years old
  7. terminator x
    4,736
    5,407
    Already? Wow time flies!
    TX.
  8. CarterRS
    CarterRS Registered User
    52
    37
    Whats the benefits from using one of these rather than paying a recognised tuner to map it?
  9. T-1000
    1,172
    1,111
    Depends if you are near a tuner I suppose.
    I’m not and was 100% going Unitronic however after coming across Dyno Spectrum I liked what was on offer, plus they are very helpful and open about what they do.
    I can add in pops and bangs myself / there’s an option to close the wastegate at lower revs/load to get rid of the rattle.
    Switchable maps and various off the shelf maps stage 1/2/2+980cc 3/4 available
    CarterRS likes this.
  10. Slowracer
    Slowracer Registered User
    338
    224
    43
    I've been looking at this myself as I'm keen to go flex fuel, but I'd still want to have a reputable local ( Aus) set up and tune for me.
    T-1000 likes this.
  11. T-1000
    1,172
    1,111
    Wastegate rattle at cold start and under light loads has now been mapped out.
    Such a great piece of kit.
    Dan_DJT likes this.
  12. Avatar
    snack-media
    Advertisement
  13. BI33
    BI33 Registered User
    30
    How do you find the data logging?
    Are the maps any good?
  14. T-1000
    1,172
    1,111
    Data logging is very comprehensive and pretty straightforward to do...... I’ve done several runs now and the car feels strong with 0 Knock across the 5 cylinders on full throttle.
    I’ve got the Stage 1 99 map on currently and it won’t be long before I flash Stage 2 once I buy the TVS DSG tune.
    Very good customer focus from Dyno Spectrum too, always reply quickly to questions.
  15. T-1000
    1,172
    1,111
    The annoying Cold start warning beep now removed.
  16. Bonstio
    117
    45
    Sounds interesting. I already had a revo but that waste gate rattle.....
    T-1000 likes this.
  17. T-1000
    1,172
    1,111
    Brilliant piece of kit in my opinion.
    No more WG rattle (or catalyst warm up phase) and no cold start beeping is worth the price in its own.
  18. Dan_DJT
    Dan_DJT RS3 Saloon
    352
    223
    43
    Has the beep when an error is set also gone ? Just wondering if the beep is removed globally or just for the cold start warning
  19. T-1000
    1,172
    1,111
    Just the cold start / don’t Rev over 5500 limiter.
  20. Dan_DJT
    Dan_DJT RS3 Saloon
    352
    223
    43
    OK thanks, nice feature.
  21. T-1000
    1,172
    1,111
    New changes today......
    Pedal box now removed as I’ve tweaked the throttle table so hopefully now that’s been sorted.
    Cete valve controller taken off and Exhaust flaps programmed to be open all the time in Dynamic mode, but can still be quiet in comfort.
    Dan_DJT and Count Drunkula like this.
  22. D0C
    D0C Registered User
    3,280
    3,090
    Sounds like a great piece of kit. How much was it? You’re already getting your money’s worth out of it by the looks of things!
  23. ArrEssDrei
    ArrEssDrei Member
    58
    24
    Wow, this sounds amazing. Can I ask a few questions:
    1. How much configuration is there for the over run tuning, can you go mild/none/asbo, or is it just a yes or no tick box thing?
    2. How much tuning knowlege do you need not to blow up the car? Is there much support for learning how to tune?
    3. Are the verified dyno figures for their tunes anywhere? Do you plan on testing your car at all?
    I have a Stage 2 car but I'd much rather learn how it all works and do it myself as there's a lot they don't offer like the valves opening fully in dynamic and the rattle fix. My tuner literally told me it wasn't possible to adjust some of things you mentioned, which tells me I'd be better off learning how to do it all myself! This kit looks like a real game changer.
  24. T-1000
    1,172
    1,111
    1) Overrun timing tables can be altered as much as you want, there comes a point though as with all these things, how much is too much, and engine longevity.
    I ran -17 deg for an afternoon and whilst it was reminiscent of my PFL car, after a while it got on my nerves, so I toned them down.
    2) The maps supplied are well tested OTS versions , you use the DS1 in conjunction with TunerProRT 5 to alter them, there are people in the FB Group that are very helpful. Dyno Spectrum support is also very good.
    3) There are graphs on DS website in WHP and bear in mind the OTS maps are conservative / Safe. But they go up to Stage 4 and support Flex fuel / ethanol /100/105 etc
    I may get the car on a Dyno at some point but I’ll more likely do Dragy runs once the winter tyres are off.
    Butt Dyno tells me it’s quick, Stage 2 is going on it next week along with TVS stage2+ DSG software.
    This is table I came across today for start up bark.....
  25. T-1000
    1,172
    1,111
    Just under 1k.
  26. D0C
    D0C Registered User
    3,280
    3,090
    Very good value IMO.
    Will look forward to further posts on it from you.
  27. ArrEssDrei
    ArrEssDrei Member
    58
    24
    Thanks very much for the info. So are the pops and bangs completely controlled by timing retardation? I assumed there was also extra fueling involved? I'd buy the DS1 just to be able to dial this in myself frankly!
    Are there any forums or anything for tunerproRT you can point me to? I'd like to start reading and learning before I pull the trigger on one.
    I hope you dyno it after you have it all dialled in as you like, but even draggy results would be really good to see.
  28. ArrEssDrei
    ArrEssDrei Member
    58
    24
    Actually, does anyone know if tuners can "lock" an ECU so it cannot be remapped again? I heard some mixed stories on this.
    If mine is locked, can I buy a stock replacement and just stick it in there, or does that have to be coded it by someone much smarter than me?
  29. Dan_DJT
    Dan_DJT RS3 Saloon
    352
    223
    43
    There is a whole function for the pops and bangs. There is an option within it for over-run and downshift noise. Only downshift noise is enabled in DAZA and in DNWA all noise is disabled. It is simply a case of turning it back on and setting some timing maps to alter the impact of the noise.
    T-1000 likes this.
  30. T-1000
    1,172
    1,111
    Go join the Dyno Spectrum FB.
    As Dan says there’s a whole section within TunerPro that contains Sound Tuning.
    There’s certain changes within sound tuning that require change for the P&B’s to take place. Also changes in the ignition tables for when and how severe.
    Dan_DJT likes this.
  31. T-1000
    1,172
    1,111
    Don’t get me wrong it won’t turn you into a tuner for me it wasn’t about that to some degree.
    But having the ability to flash myself and have some insight into what goes on in an ECU is worth the asking price alone.
  32. ArrEssDrei
    ArrEssDrei Member
    58
    24
    Really interesting, thanks dan and t-1000. You guys both seem really knowledgeable, Is there anywhere else I can learn more about tuning, or tuning software and strategies? I've joined the FB group.
    t-1000: I'm curious if your valves being open all the time in dynamic includes on start up? Are you able to lock startup in a true dynamic mode, or does it still default to comfort but keep the valves open?
    T-1000 likes this.
  33. Avatar
    snack-media
    Advertisement
  34. T-1000
    1,172
    1,111
    Still need to select individual / dynamic as I’m told the ECU isn’t 100% in control of Drive select modes it shares that with central electrics.
    The Remap mimics the Cete in keeping the flaps open fully.
    If I want a quiet start I just put it in comfort.
    I suppose I could have left the Cete on it but just didn’t see the need for it anymore.
    Car is bonkers loud now on the Stage 2 file I’m running.
    The idle and low down sound is so much better than stock / stage 1.
    ArrEssDrei likes this.
  35. ArrEssDrei
    ArrEssDrei Member
    58
    24
    The DS1 sounds really well thought out if it can offer all of that - it's more than most pro tuners give for their stage 2++ tunes.
    T-1000 likes this.
  36. oz_rs3
    oz_rs3 New Member
    This is a really nice looking piece of kit.
    At what Stage can pops bangs be enabled?
    Does it require Stage 2 like most remaps?
    Presumably the GPF needs to be removed for those with a DNWA?
  37. Dan_DJT
    Dan_DJT RS3 Saloon
    352
    223
    43
    Pops and bangs can be enabled at stage 1 and I do so for the maps I work on. This includes the DNWA with GPF. We have bought a DNWA car (we also own a DAZA) and have done many thousands of miles to ensure robustness on our stage 1 with pops n bangs. This includes some extreme testing at Millbrook Proving Ground.
    oz_rs3 likes this.
  38. T-1000
    1,172
    1,111
    Any stage, the procedure is pretty straightforward if you are ok using TunerPro.
    I actually did some testing of various stages of ignition adjustment to see what was possible and how it sounded, now I have a sound that I really like.
    Dyno Spectrum are currently putting the finishing touches to their DNWA maps.
    ArrEssDrei and oz_rs3 like this.
