Facelift Dust caps seized on..
JDHOWELLS Aug 10, 2018
  1. JDHOWELLS
    JDHOWELLS Well-Known Member Audi S3
    264
    468
    So got some lovely blue metal dust caps on my car when I got it last year... bloody things are seized on.. any great ideas to get the things off?
  2. Avatar
    Google AdSense Advertisement
  3. Svenedin
    Svenedin Well-Known Member Team Navarra Audi S3 quattro S tronic It's my birthday
    695
    510
    93
    WD40 or similar (Plusgas etc). Leave it long enough to penetrate into the threads. It's dissimilar metal corrosion. You'll need to spray from behind to have a hope of getting into the thread. A minuscule bit of grease will stop it happening again.
  4. jassyo06
    jassyo06 Voodoo Man ! Gold Supporter Audi S3 Black Edition Porsche Voodoo Blue S3 Saloon
    16,873
    34,525
    You'll need A junior hacksaw and a set pliers to get them off.....split the cap in half at the top with a junior hacksaw blade then try and peel them off.....happened to me on my last S3....its....a tricky job
    Rob2k68 likes this.
  5. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User MQB Platform
    7,327
    11,123
    You may get away with mole grips but don’t squeeze so hard such to damage the valve.
    Sent from my iPhone using Tapatalk Pro
    jassyo06 likes this.
  6. jassyo06
    16,873
    34,525
    Yup l tried pipe grips/gland pliers as us sparkys like to call...em.....nope.....didny work.....
    Rob2k68 likes this.
  7. JDHOWELLS
    264
    468
    I’ll give this a go first, if not hacksaw it is
    jassyo06 and Rob2k68 like this.
  8. josul
    josul Active Member Team Daytona Audi S3 Sportback S tronic
    228
    158
    43
    :wtf:.... you have not checked your tyre pressure this year? Or am I reading too much into that!!!???
    Good luck in getting them off.
    KenL likes this.
  9. Svenedin
    695
    510
    93
    I have the Audi metal caps and one of those got stuck even though I usually check my tyre pressures fortnightly. It did come off with WD40 and it has not happened again since I applied a tiny bit of grease.
    JDHOWELLS likes this.
  10. cuke2u
    cuke2u Well-Known Member TFSI Owners Group saloon Audi A4 S-line owners group
    10,635
    4,078
    Any metal dust caps need to have copper ease applied as the two metals of the cap and the valve will react to each other. I have heard that cola is also good for unseizing them...
  11. JDHOWELLS
    264
    468
    Yeh yeh so I don’t check my pressures weekly or whatever... cue the car maintenance Nazi’s.. I’m of the opinion if there is an issue the monitoring system will let me know, and I check them before any long journeys, hence realising I now can’t get them off!
  12. Avatar
  13. JDHOWELLS
    264
    468
    Coke has many uses, though it has to full fat no nonsense coke
  14. josul
    228
    158
    43
    Don't take my comment as having a go, was all in jest. I don't check mine as often as I should. But I would never leave it down to the ABS system to tell me, it doesn't work like that.
  15. KenL
    KenL Well-Known Member
    1,030
    715
    Try wearing a rubber glove! Much more purchase.
  16. cemerson
    cemerson Well-Known Member Team Cosmos TDi Audi A3 quattro S-line owners group DSG
    4,667
    1,208
    ...and this is the problem with metal dust caps!
    ASBOST likes this.
  17. ASBOST
    ASBOST Member
    52
    22
    Yip, had them on the Scirocco.... Never again!
  18. JDHOWELLS
    264
    468
    Half a can of WD40 and a hacksaw to 3 of them and all four are off!
    Never again putting after market caps on, they look nice but not worth the risk
  19. Svenedin
    695
    510
    93
    The genuine Audi metal ones are just as bad. It’s a problem with all metal caps.
  20. JDHOWELLS
    264
    468
    Yeh but if the Audi ones get stuck on then it’s Audi who have a responsibility to get them off.. I asked at the dealership yesterday..
  21. Svenedin
    695
    510
    93
    Not entirely sure about that. My car didn't come with them fitted. I added them but they did they did come from Audi directly.
  22. Khufu
    Khufu Well-Known Member
    5,881
    94
    ive copper slip on mine, i occasionally fit tyres and i know the problems that happen if you dont.
