hi has any one fitted a soilid mass flywheel to replace the dueal mass iv found a kit do any of you think its any good or can i get it cheaper eBay - The UK's Online Marketplace
If you search around you'll probably find pro's and con's to both.. depends on a few things - how much you plan on tuning it and how you drive it I guess?..
Yes mate you should get the kit alot cheaper than £400+. Go with the g60 flywheel and vr6 clutch as suggested as these are all original OEM parts, or carspares and gsf and eurocarparts all do an aftermarket alternative.
Tdi 130 will be a 6 speed box so the g60 flywheel/vr6 clutch will not work. IMHO get a new Sachs/luk clutch and dual mass flywheel, they work well on the 6 speed box anyway.
