DSG gear selector unit
Tim17
Hi all,
I recently bought my partner a 2.0tdi DSG A3, 2005 l, 130k miles
It has had an engine management light on since I got it, VCDS throws up a fault code of 28775 - No comms with gear selector unit.
A few days ago I replaced the whole gear selector unit in question (which wasn’t quite as difficult a job as I thought it might of been) the part was second hand from a breaker on ebay.
However, I STILL have exactly the same problem and code! Fuming
So I guess my question is, does the selector unit need any special coding on VCDS when being replaced?
Or may be the replacement unit I bought has exactly the same problem as the original one.
I really have no idea any more, I’ve spent hours trying to find a solution on the internet.
It doesn’t really bother me all that much, but the problem is it won’t pass an MOT with the engine management light on!
If any of you have any ideas or suggestions I’d much appreciate it
Reactions: CDan
you scanned with VCDS and got what codes? only 28775 or others
you may have done the right thing in the end BUT I would never purchase before investigating the fault code and making sure thats the only issue. You may have done this but money has been wasted on this forum changing stuff that is functioning perfectly well when its something else. In your case, I am wondering what other codes occurred as cangateway can aslo be a problem connecting to the TCU or the wiring to the unit itself
Reactions: Tim17
Thanks for the reply, the reason I went ahead and changed the whole selector unit is because to me it seemed the most likely culprit.. Plus I am fairly confident mechanically but not with checking/diagnosing electrical faults, I have VCDS which I only got very recently so very limit know how on how to use it etc.
Anyway, the car will (not very often) flash up the PRNDS on be cluster, it will allow the car to start, but the gears are locked and it doesn’t let you move the gear selector, but usually switching the car on and off again once or twice resolves it and works fine.
So the 28775 code is there permanently, but when the PRNDS flashes and locks out it also throws the codes
00511
00194
02413
Other issues I’m having with the car are (probably not related but to be thorough)
00888
Also an intermittent one for steering wheel airbag N95, something like upper limit exceeded but I can’t remember the code right now
I have found the microswitch previously, pressed it in and out about a hundred times, cleaned it up, and monitored on VCDS whilst moving into park and other positions and it was tallying up perfect.
Like I say, I’ve spent hours searching forums and google, I think I need more specifics now for example how do I check the cangateway operation or the TCU?
Need to see diagnostics to see what's throwing the error.
Reactions: Tim17
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC 0000AG 7000
Revision: 12345678 Serial number: AUX7Z0E3FNP05X
Coding: 0000078
Shop #: WSC 01286 386 08256
VCID: 78A9EFECEED05957F17-802C
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 041 A HW: 02E 927 770 AD
Component: GSG DSG 070 0822
Revision: 00007000 Serial number: 00000504190185
Coding: 0000020
Shop #: WSC 00046 412 262144
VCID: 1079B74CE6606117597-8044
3 Faults Found:
28775 - No Communication with Gear Selector Module
U0103 - 000 - - Intermittent - MIL ON
00511 - Selector Lever (E313)
004 - No Signal/Communication - Intermittent
00194 - Ignition Key Removal Lock
008 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 00046 412 00000
VCID: 3A2D35E4905C8B47C73-806E
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH15 0200
Revision: 188079 Serial number: 8P0820043H
Shop #: WSC 00046 412 409600
VCID: 313F12C84D2A481F769-8064
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H37 0301
Revision: 00H37000 Serial number: 00000001855387
Coding: E5885F06A214100000000000000000000000FE0F5C
Shop #: WSC 00046 000 778240
VCID: 3D273EF88172BC7FE21-8068
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00046
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00150573
Shop #: WSC 00046
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011603
VCID: 43D34800E796CA8F945-8016
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 B HW: 8P0 953 549 B
Component: Lenksäulenmodul H21 0050
Coding: 0011112
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0040
2 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
02413 - Switch for Selector Lever Position P Lock (F319)
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D06 Serial number: 2243ED06009868
Coding: 0000413
Shop #: WSC 00581 067 57207
VCID: 363521D4A4446F2723B-8062
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500105501820D
Coding: 3F0F0B42070101
Shop #: WSC 00046 000 770048
VCID: 2809FFAC7EF009D7A17-807C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D06 Serial number: AUX7Z0E3FNP05X
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0040
Coding: 0000120
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.8 1502
1 Fault Found:
01314 - Engine Control Module
Freeze Frame:
Mileage: 160 km
Temperature: 21.0°C
Voltage: 13.00 V
Voltage: 12.70 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H03 0040
Coding: 018000186D288505489AC63300
Shop #: WSC 00751 210 16420
VCID: 79AFEAE8D5DA405F8E9-802C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001223503
VCID: 70B9D7CC86A00117397-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000120
VCID: 3E2539F48C74A767FBB-806A
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3E2364363
Coding: 0001001
Shop #: WSC 00046 412 270336
VCID: 323D1DC4482C73070F3-8066
Have you tried clearing the errors doing an ignition cycle rescanning?
What about the ignition switch on the end of the barrel?
I'm wondering if it's a wiring issue.
Yes tried that, they all clear the but the 28775 code always comes back after a short period of time, and then if the flashing PRNDS happens I also get the other codes with it (apart from the wiper switch one etc)
The ignition switch fault code is because it doesn’t let you release the key when the PRNDS flashes if that is what you mean?
I’m at a bit of a loss with it all, a few other situations I have read about usually get sorted by replacing the selector unit, but obviously I can’t rule out that my used one doesn’t have the same problem as my first one (if that’s even the issue)
I'd go with wiring & I'd consider swapping ignition switch out to be sure as these are known to have issues occasionally.
You could temporarily have some fun hot wiring the car and disconnecting the key barrel.
Just need 2 switches, and your key for the immobiliser.
just to verify it is the root cause
Excuse my ignorance, but can you explain the relevance of the ignition switch in relation to my issue? Thanks for the replies
You have VCDS ands you have Ross Tech fault codes and you have access to the ross tech fault codes on the interwebs. The fault codes reference control modules which are easy to find if you use the interwebs. You have a wiring issue as stated above. That wiring issue requires you investigate the referenced control modules to see if they are getting power and if so then they are likely not communicating and need to be replaced. The key barrel relies on a control module which is underneath the steering wheel hub. I have seen that control module lose its physical connection on a few cars which is why the above reference direction to check the ignition switch. I really don't think anyone here can fix it for you by typing in a response. Nigel is IMHO most trusted and competent and has given you excellent advice. I really think you need to either find the control modules and work through the issues stated on the ross tech site or just bring it to a local dealer and have it fixed
Please don’t be condescending, I am not asking any one to “fix it for me”. I am asking for advice from others who have more experience than I do on the electrical side.
I asked specifically what the relation was between the ignition switch and the issue I am having, which even though you made a very long reply you haven’t really explained either so can you explain to it me or do you not know either?
Not really sure what the point in your reply was other than to state the obvious as there was nothing useful or factual in there. I can only assume the ignition barrel shares the same control module as the gear selector or something along those lines?
Check out this PDF of the 02E DSG which explains a little on how the shiftier relates to the ignition lock.
http://www.evosoft.dk/diagrams/DSG_02E.pdf
Its from VW but that 02e DSG box is pretty much the same as in our Audis.
Pages 6-11 is what you probably want to read through.
I would check that control module under the steering column (J527) first and see if the harness is properly connected. Next would be to check for breaks in the wire runs from the harness on J527 to the selector. This is best done with a wiring diagram to identify which pins \ wire runs to focus on. Maybe someone that has access to ELSAWIN can help you out with the diagrams for your car.
I don't think he was meaning to be at all, so let's step out of any possible friction.
The ignition switch basically signals via key positions to the cars systems to turn on, it's a plastic mechanical switch with internal positions that have circuits integrated to signal via a wired connector to enable the car like the canbus, immo, gear unit, etc etc.
They are known to go faulty, given they're only about £40 I'd try one.
Hi all,
Hi, You managed to solve the problem with PRNDS Flashing, if so how did you manage, I have the same problem!
You need to check for the fault codes on the car. There are many faults that will cause the PRNDS to flash, Getting the car checked for fault codes will be a start. I suspect the OP had an issue with the wiring as he replaced the complete gearchange mechanism and it was still faulty.
