DSG "clunk" 3rd to 4th gear
tickedon Nov 26, 2018
  1. tickedon
    tickedon Member Team Moonlight TDi Audi A4 S-line owners group S tronic
    71
    32
    Hello all
    I have a 2017 Audi A4 2.0 TDI S-Line S-Tronic. Some time ago, I noticed I could hear a 'clunking' sound the first time the gearbox switched up from 3rd to 4th gears after starting the car. Every other gear change after that, there are no unusual noises - only the first time from a parked start. It doesn't matter whether gearbox is in normal/sport/efficiency etc.
    I've tried to capture the sound, two recordings:
    https://vocaroo.com/i/s1DLIkdTTQVY
    https://vocaroo.com/i/s1guBuDCWkZ2
    (the first one is probably better, about 6/7 seconds in)
    I have the car booked in for it's second service next month and I've asked them to take a look, but does anyone have any ideas? Given it always (and only) happens when the gearbox switches from 3rd to 4th gears after a parked start, I'm assuming it's something related to the DSG box... but perhaps others have a better idea what it might be!
  2. Avatar
    Google AdSense Advertisement
  3. WesT-gefül
    WesT-gefül Well-Known Member Bronze Supporter
    764
    251
    Does it happen every time without fail no matter the terrain. Sometimes if the mechatronic pre selects a higher gear but the terrain actually means it needs to go down one you can hear that especially when slowing down. The sound isn’t clear and to be honest don’t think you’ll get help on here. It’s the sort of thing that needs look at.
    How does it feel since you had it? I had my gearbox replaced but it was to do with juddering. Don’t be alarmed though as mine was a edge case. Get it looked at whilst in warranty because it’s big money out of warranty.
  4. tickedon
    71
    32
    Happens the first time I start the car from parked and it changes from 3rd to 4th, without fail - whether going uphill, downhill, still on the flat, using accelerator gently, pushing accelerator harder... After that first time it's switched up from 3rd to 4th, there are no other unusual noises and I never hear it again (until I've parked, and start the car again...)
  5. WesT-gefül
    764
    251
    Definitely get it looked at. It’s one for Audi though. I’ve got my money on the Mechatronic unit but that’s just a guess.
  6. cuke2u
    cuke2u Well-Known Member TFSI Owners Group saloon Audi A4 S-line owners group
    11,030
    4,276
    Are you sure it isn't the abs self test...
    Daggerit likes this.
  7. Spaceman_RS3
    Spaceman_RS3 Well-Known Member Team Ibis Team Panther Audi RS3 Audi S4 Audi Avant Owner Group
    1,456
    841
    I’d guess it’s that in auto it will be changing 3/4 around the speed it does the test
  8. L_G
    L_G Active Member Team Daytona Team V6 Sportback Audi S5
    182
    69
    Don't think I have noticed this before, what are the symptoms?
  9. cuke2u
    11,030
    4,276
    A clunk from the footwell area only when the car is first started. After that it will not repeat it until the engine is turned off...
  10. Spaceman_RS3
    1,456
    841
    Try from first start driving in manual hold 3rd longer and see if the clunk happens without the gear change
  11. tickedon
    71
    32
    Thanks, that is a good idea - I’ll give it a try!
    Spaceman_RS3 likes this.
  12. Avatar
  13. Kevin Gall
    Kevin Gall New Member
    26
    Get it looked at asap dsg box has known problem with 3rd 4th gear my m8s went in his dsg a3 3000 quid to get fixed only 30k on clock aswell!!!!!!
    Sent from my SM-G950F using Tapatalk
  14. cuke2u
    11,030
    4,276
    That depends upon it is the same gearbox. The difference us that it is tranverse in the A3 but the A4 has a longitude one..
    Happy Grumpz likes this.
  15. Filipão
    Filipão Active Member Audi S4
    170
    91
    The ABS sounds happen everytime the car is started and running (at a straight line) and are a series of 3 or 4 "clunks", not only one.
    On my two LHD B9s, it comes from the left hand side (near side for UK/Oz) foot well.
    I'm pretty sure on RHD the unit is located at the same place, so it maybe harder for you to hear it if you're in the UK.
    SMI77 likes this.
  16. cuke2u
    11,030
    4,276
    Strange you should say 3-4 clunks as mine only does one and it doesn't matter if I am in a straight line of not, it is always at the same speed.
    It is in the same place and you can hear it..
  17. tickedon
    71
    32
    Spent 10 minutes in 1/2/3rd (“joy” of traffic and 20mph zones) - no noise until clear and as soon as went up to 4th, ‘clunk’...
  18. cuke2u
    11,030
    4,276
    So what was the speed when this clunk happened...
  19. WesT-gefül
    764
    251
    Get it in to Audi to avoid further issues.
  20. Filipão
    170
    91
    Hi @cuke2u it may sound like one, but it's a rapid series of several.
    I would say 3 clunks in a row.
    I am pretty sure it's from the LHD driver's footwell (left side of the car, so my side)
  21. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 Audi Avant Owner Group quattro
    3,088
    1,567
    I'm pretty sure it doesn't happen until 27mph, try holding a gear until then and see what happens.
    cuke2u likes this.
  22. Tobiasbg
    Tobiasbg New Member
    Hi there. Just bought my Audi A4 b9 2016, and noticed excactly the same Sound as you. Have you found out what it could be causing
    The problem?
  23. cuke2u
    11,030
    4,276
