- Joined
- Oct 17, 2004
- Messages
- 425
- Reaction score
- 60
- Points
- 28
I have some issues with my Audi S3 8L keeps dropping connection or wont connect.
Problem is i had ABS light on and wanted to reset, error codes were related to the pump and a sensor but halfway through the connection would drop. Same if im attempting to connect to Engine module. Its very intermittent.
Strangely seems ok when i first connect then progressively worse where it disconnects and i can't connect again.
I read that faulty devices can cause interference on the kline? So i unplugged the ABS module complete and still have the same issue trying to connect to the ECU or engine module.
Id appreciate some help here how i may diagnose. I have 3 obd readers VCDS/OBdeleven and a standard OBdreader (Xtool) unit which all work perfect on my other S3.
Thanks!
Thanks!
