So as said my drop links are coming loose after lowering on ap coilovers, i bought some shortened ones when i bought the coilovers do i need them or not. Same thing happened on my mates car until we put some washers between the bolts and the struts
You shouldn't need loctite, had my ap's and ran them for around 2 years on different cars and never had any knocks or rattles.
The nuts are 18mm if I remember correctly so can take a fair amount of force when being tightened. Be a bit more manly with it if that is where the problem is.
Just a thought are links fitted the correct way?
One side when bolted to the strut should face forward and the other back.
Just wondered why they come loose as it's not a problem I've came across.
