Drl to LED
Burf
I’ve had a drl go down on my b8 Audi want 180 for the bulb is a swap to led a better option or can anyone assist in where to buy one at a more reasonable price please.
Marky007
A4 Sline
£180 thats expensive :sadlike: what year is your car.
Must be a cheaper option on ebay or similar.
kanecullen89
I've been looking into this myself.
Seems like a fairly easy job to swap the bulbs. Mine are still working fine but Id rather have a more white look than the halogen yellow so LED.
P13W are the bulbs required and to access these, the headlights needs to come out (fairly easy) and a couple of predefined holes cutting in the rear of the plastic. replace bulbs then seal up the holes again with silicone/rubber caps.
This thread will give you some more info:
https://www.audi-sport.net/xf/threads/a4-b8-drl-replacement-to-led.233121/
ion2211
£180 for a p13 halogen bulb? That is HILLARIOUS!!! - The bulb is worth £2!
Are you sure they are not quoting you for a completely new Headlight?
As for replacing the bulb, replace it yourself with a LED. It's quite a common mod and very easy DIY job
Burf
Cheers for the info. Will definitely do it myself. That was not for a headlight that was the bulb and then he said I’d have to book it in for fitting. I think it was a halogen bulb. I was too busy laughing at him to pay much attention but he may of said it was gas would this be different?
