Drivers Seat Not Working and Missing Fuses?!
Lyons Jun 22, 2018
  1. Lyons
    Lyons A7 / Mk7 R
    183
    13
    I noticed yesterday that the main electric controls for my drivers seat aren’t working, however the lumbar is still operating as it should. I checked the manual and both have their own fuse, so this was my first port of call. When I opened the cover, it appears that most of the fuses are missing, including ones for things they are actually working?!
    Can anyone shed any light on this?
    Also, any other ideas why the electric seat may have failed? I expect there’s not a lot of room to check wiring below.
  2. Avatar
    Google AdSense Advertisement
  3. Stokka
    Stokka Active Member
    100
    42
    get your head under that seat mate, aggggggggggges ago i had one of the kids knock a plug off under the seat, i used my smallest most competant child at the time to pop it back on coz i didn't fit lol
    Lyons likes this.
  4. NHN
    30,060
    1,902
    Check if the empty fuse points have a pin in each fuse leg as such, if not then theyre unused fuse locations.
    Ideally after fuse checks, a meter or diagnostics.
    Whereabouts are you based?
    Lyons likes this.
  5. Lyons
    Lyons A7 / Mk7 R
    183
    13
    In Belfast.
    I’ll check the fuse legs later, cheers. Is it not weird there’s loads missing for things I do have but, which are all working?!
    Checked under the seat there and couldn’t feel/see any loose plugs.
  6. Lyons
    Lyons A7 / Mk7 R
    183
    13
    Right, there’s only 1 pin in each of the fuse kegs which are empty. My car has electric seats for example, so where on earth js the fuse?!
  7. NHN
    30,060
    1,902
    Could be thermal fuse in footwell outside edge behind trim.
    Lyons likes this.
  8. Lyons
    Lyons A7 / Mk7 R
    183
    13
    Literally just read about thermal fuses.
    Any way to identify which would do the seat?
    Also have this code;
  9. NHN
    30,060
    1,902
    Seems no power to the module, hence no seat electrics.
    You'll have to check fuses visually.
    I'm trawling through schematics for a Q7 job atm so I can't help currently.
    Lyons likes this.
  10. Lyons
    Lyons A7 / Mk7 R
    183
    13
    No problem at all, I’m in no real panic. I appreciate your help thus far!
    I’ll hve a google and see if I can find the thermal fuse box in the interim.
  11. NHN
    30,060
    1,902
    Check right side trim of footwell, thats whwre some seat thermal fuses reside on some chassis.
    Lyons likes this.
  12. Avatar
  13. Lyons
    Lyons A7 / Mk7 R
    183
    13
    Cheers. Looks like an absolute nightmare removing that trim behind the bonnet release, so will look at it when I get back from holiday.
    The only other thing is I spotted on the book there’s a fuse for electric seats in the boot too. I’ll have a look in there on the off chance it’s the culprit.
  14. NHN
    30,060
    1,902
    Without checking your chassis codes it could be front, back, etc.
    Lyons likes this.
  15. Lyons
    Lyons A7 / Mk7 R
    183
    13
    Would I be wasting my time pulling out all the normal fuses and checking every single 1?! Could it be linked to another component?
  16. NHN
    30,060
    1,902
    1st thing i do is check power with meter, then go from there
  17. Lyons
    Lyons A7 / Mk7 R
    183
    13
    Check power where?
  18. NHN
    30,060
    1,902
    Under the seats.
    Lyons likes this.
  19. Lyons
    Lyons A7 / Mk7 R
    183
    13
    On holiday now for a few days, will try and have a look when I get home. Thanks again.
