Drivers lock part number for January 2006 Sportback 2.0TDI
rabbituk
Recently my OSF (driver) door is unlocking intermittently on the key fob, mostly it does not work. I'm still able to unlock with the key. Pressing the interior unlock button has the same problem as the key fob. Strangely/thankfully I can open the door from inside. The other doors all unlock/lock as normal. I've greased the catch mechanism but it has had no effect on the actuation of the lock. My thoughts are that the problem lies either with the wiring or the lock actuator. I've had a quick visual glance at the wiring around the A pillar and cannot see any breaks or fraying there. My next step is going to be taking the door card off and pulling the window out. Before I do this I would like to have a spare lock actuator on hand but am unsure of the part number. Is 4E2837016 correct? I've seen some parts with letters after e.g. 4E2837016AA and 4E2837016G. Would they also fit? I did ask my local Audi dealer if they could tell me the part number but they sadly refused to provide the information.
Here is the relevant VCDS information from a scan yesterday. Additionally after attempting to unlock/lock several times in quick succession the central locking stopped working. It appears to have a thermal cut out which was triggered which is mentioned below. I don't necessarily think this is a fault at the moment.
Code:
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0000688
   Shop #: WSC 06314 000 00000
   VCID: C0850526932FAC4129-8094
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
            012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal - Intermittent
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 C
   Component:    KSG          H04 0050
   Coding: 198000186D088505489FC63300
   VCID: BC7D71D6FFC7C8A175-80E8
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H03 0020
1 Fault Found:
01038 - Central Locking Thermal Protection
            000 -  -  - Intermittent
Many thanks for any help.​
rabbituk
Thank you for the link. Site bookmarked! That is a really useful site to know and has just the information I was asking the dealer for.
rabbituk
Advised door lock purchased and installed after an hour of play. Thanks for the correction on the part number, much appreciated. The door lock was quite easy to install compared to a handle I worked on the previous day - no need to take the window out.
