  2. Dismiss Notice
Drivers Door Unlocking Fault
S3Steve Oct 15, 2012
  1. S3Steve
    S3Steve Registered User
    1,604
    21
    My A3 has developed a strange fault, the drivers door no longer unlocks with the key fob, it locks ok but will not unlock. All the other doors still work with the fob for both locking and unlocking. I now have to manually unlock the drivers door with the key. The problem started a few weeks ago and was intermittent at first but now seems to be permanent. Ive had a quick look over the door loom and it all seems ok. A vagcom scan when the fault first started showed this
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H02 0040
    Coding: 0000560
    Shop #: WSC 06314 000 00000
    VCID: 438EF153029458007C7
    3 Faults Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    01552 - Motor for Central Locking; Drivers Door (V56); Lock
    012 - Electrical Fault in Circuit - Intermittent
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    008 - Implausible Signal - Intermittent
    Has anyone else had this fault? What was the cause?
    Also does anyone have a wiring diagram for the door loom so i can check it properly?
