- Joined
- Nov 1, 2013
- Messages
- 11
- Reaction score
- 1
- Points
- 3
Hi Guys,
I have a 2009 A3 8P3 Sportback which the driver's door won't open remotely with either key. All other doors and boot open and I can unlock the drivers door by using the key in the door or opening it from the inside. The drivers window will open using the key (holding the unlock button) or using the button on the inside; remotely locking works fine as well.
Below are the VCDS errors:
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8P0 920 982 E HW: 8P0 920 982 E
Component: KOMBIIMSTR. VDO H19 0860
Revision: D0H19007 Serial number: AUX7Z0I1FNA0J7
Shop #: WSC 00000 000 00000
VCID: 3B7E40F67AB1FCC6811-806E
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0004860
Shop #: WSC 06314 000 00000
VCID: 42803D121D5B8D0EC27-8017
2 Faults Found:
01552 - Motor for Central Locking; Drviers Door (V56); Lock
012 - Electrical Fault in Circuit - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
I found the below threads with similar problems although they didn't have the "25-Immobilizer Key" fault and never mentioned the final fix. The sticking of microswitches sounds possible as once I open the door (with the key or from inside) I will be able to lock and unlock it fine with the fob, the problem will then reappear after leaving the car locked for an hour or more)
http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/181144-drivers-door-lock-problem.html
http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/172972-passenger-door-central-locking.html
http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/175494-drivers-door-lock.html
I would appreciate all of your opinions/insight.
1 Fault Found:
01176 - Key
Coding: 0004860
2 Faults Found:
