[ QUOTE ]
I'm happy getting a new enclosure if it's only £18 but would never try fitting it myself. And I guess that if I went to Lancaster Audi they would charge a fortune to fit it. I haven't found any independent Audi specialists in South Manchester so would just be going to local independent (non-Audi) garage.
So what's the part number for the enclosure and how easliy/quickly should they be able to get it? How long would you expect to fit it including taking door apart and back together?
Thanks,
Nick
[/ QUOTE ]
I should be able to give you the part number later, as I've got the box my new one came in somwhere in the shed. My indie was able to order & get it from the dealer within 48 hours. Fitting it really is not very difficult. Trust me. If I can do it, anyone can.
The fiddliest part is removing the door card. That's just a case of removing a number of screws (including one or two concealed behind a trim part on the grab handle), and then gently raising the card until it's clear of the locking pin.
Ease it clear of the door, & working on the back of it, unclip the door release cable from the handle assembly. You might need to disconnect the connector plugs for the speakers & mirror adjusters to get enough clearance. Then, unscrew the assembly itself from the card, and disconnect the connector plugs for the central locking switch & tweeter.
After that, refitting is a reversal of removal, as they say in the Halfords manual.
i'll get you that part no. tonight
