What set up are folks using in icy / snowy driving conditions to provide the best grip / traction.
Only asking as I've not had it on a car but will do soon.
To repeat GSB...."Nothing Beats a Set of Winter Tyres"
That's because Canada turns into a mini Alaska come winter lol
It is full time... ...almost.So, am I right in saying the Hapdex 4WD is a part time system? I assumed it was full time Quattro?
I'm not so sure that it's because people in the U.K. dont get the benefit of winter tyres.
The number of days of icy / snowy weather these days probably mean that most consider it an unnecessary expense. Now hindsight is a great thing and following a collision due to loss of grip most would then wish they'd spent the money but that's not how most folk think. In countries where these wintry conditions run continuously for weeks and months on end then the decision is much easier to make.
Try manualSo, am I right in saying the Hapdex 4WD is a part time system? I assumed it was full time Quattro?
Only other thing to note, what's pretty rubbish with the S Tronic is not being able to change into 2nd until you are above 10mph, very daft.
I have low ratings of the S Tronic Tiptronic setup, with how much it changes gear on its own.. it should let you hit the rev limiter, perhaps unless you are launching.
Countless times I've accelerated hard, changed from 2nd to midrange third and as soon as I backoff it's changed into 4th.. really irritating.
Try manual
TX.
Sent from my STV100-4 using Tapatalk
I'd noticed that it sometimes won't change up to 2nd at low speeds however I'd never twigged that it was speed limited in some way so appreciate you noticing! My original comment was more aimed at the car changing gear when you don't want it to generally eg stick it in manual and change when you wantI have, that's what I meant I cannot manually change to 2nd gear neither at a standstill or below 11mph. If I try to change into second at 10mph and below, no matter how many times you pull it doesn't nothing. Once you reach 11, it changes right away.
TX.
True, but up in Bonny Scotland and a lot of other parts in the UK, is it worth the risk? The A9 and most highland roads are not fun in the winter, even with spotty gritters.
Also where I live ...Vancouver BC ....all emergency vehicles are equipped with winter tyres and the climate is similar to Edinburgh/Glasgow in the winter. I would also state that 65% of other vehicles have winters and the balance all season tyres.
It won't change up in manual and will hit the rev limit. Are you saying yours auto changes UP when in manual? Mine will change down in manual if I'm going too slow for the gear I'm in but it has never changed up for me.
TX.
First shown at the Great Exhibition of the Works of Industry of All Nations in 1851, this is a fine example of Messrs Borg & Warner's improved Brunellian cog swapping apparatus for horseless carriages.What the hell is that
TX.
Perhaps the gearbox isn't in sport? If you put the car in dynamic it will be sport gearbox (or pull back on the stick), try that? I've launched in manual by mistake and the car stopped like it had hit a brick wall at the limiter, it did not change gear on me ...
TX.
Give it a try in full on dynamic as imho it's changing up on you as you're not in sports gearbox. I'll try and hit the limiter in mine whilst not in dynamic as a comparison
TX.
Edit - tbh I'm rarely near the limit and often don't even give the car full beans! It's wasted on me
Well it must be a FL or S3 thing as in auto mode normal gearbox (manual paddles) mine hit the limiter in 2nd. No auto change up.
TX.
You can always swap with me mate....Give it a try in full on dynamic as imho it's changing up on you as you're not in sports gearbox. I'll try and hit the limiter in mine whilst not in dynamic as a comparison
TX.
Interesting issues. Guys, are you aware that Audi now provide a no-cost option that removes these unwanted shifts and allows you more control over gearbox functionality?
