  2. Dismiss Notice
Facelift Drive Select on startup
Bonstio May 13, 2018
  1. Bonstio
    Bonstio Registered User
    116
    45
    Hello.
    When I start the car, it shows the mode in use when I turned the engine off which is normally dynamic. However, it's quite apparent that the car is not really in dynamic mode. This means I have to hit the drive select button 4 or 5 times to cycle through all the modes until I'm back at dynamic.
    This is annoying and couple with it, my steering wheel button (which I have mapped to drive select too) is bit unreliable, especially when the thing has just turn on.
    Anyone else have this issue?
    Thanks!
  2. Avatar
    snack-media
    Advertisement
  3. T-800
    T-800 Guest
    Standard Audi I’m afraid.
    It always drops out of Dynamic.
    Star button is known to be patchy at best on the FL car, maybe they will fix it one day with an update....as well as the poor reversing camera imagine being squished.
    As you say either toggle round to it or have it on the MMI display then you just press the large jog wheel once to re-select Dynamic.
  4. Bonstio
    116
    45
    Thanks for the reply.
    I wouldn't mind it dropping out of dynamic. It's just an obvious software bug which continues to show dynamic mode :( Agree that it seems like a software update could address this and the button.
    Somewhat related, I'm trying out Carista to tweak a few settings. It's rather limited but what's there seems to work.
  5. AB RS3
    AB RS3 2018 Ara Blue RS3
    34
    When you just turn the car on, it's not possible to instantly go into the drive select modes as it needs to configure itself. Wait a few seconds and then you can. This drive select issue happens on the Q5 we have too.
  6. T-800
    T-800 Guest
    I go into the Drive select every morning before the cars even started via the button.
    E15 likes this.
  7. Dan_DJT
    Dan_DJT RS3 Saloon
    338
    214
    43
    You dont need to wait for the pop up screen to configure itself, you can change drive modes straight away using the display on the virtual cockpit.
    T-800 likes this.
  8. KKOG
    KKOG Registered User
    89
    42
    I find it fascinating that a huge company like Audi obviously ignore these faults during development.
    I mean it couldn't take that much effort to 1. Make it say "Comfort" on every start up and 2. make the star button work properly.
    Richard Rushen likes this.
  9. billymc92
    billymc92 2018 Ara Blue Facelift RS3
    667
    726
    93
    It’s not that it doesn’t work, it’s because your trying to push it right away. If you look on the VC on start up it says “initialising” and as soon as that’s away it works fine. I admit it’s a bit slow but it’s just needing time to boot up rather than a fault.
    AB RS3 likes this.
  10. T-800
    T-800 Guest
    Actually there is a fault with the * button on the wheel, sometimes it works fine, sometimes it takes ages to start working.
    Lot of FL owners have this issue.
    A result of Audi overhauling the MMI and not ironing out the bugs, such as the reversing camera image that’s squished because they couldn’t be bothered to do it like the FL Golf which is fine.
  11. terminator x
    terminator x Registered User
    4,703
    5,367
    Not a fault though they do it like that on purpose just to avoid then next driver of the car being "surprised" by sporty dynamic mode.
    Agree though it should default to comfort every ignition cycle.
    TX.
    AP Racing front + rear brakes in for sale section
  12. Avatar
    snack-media
    Advertisement
  13. Snake Pliskin
    Snake Pliskin Well-Known Member Supporter
    4,625
    6,922
    start up sequence for me is ....
    a) start car
    b) toggle MMI to comfort and back to individual
    c) turn off start stop
    Good to go :icon thumright:
    Dan_DJT likes this.
  14. Marshy
    Marshy Settled in
    1,748
    716
    If you turn the car off in dynamic, when you restart is it not just a case of when selecting drive on the gearbox select S?
    I thought everything stayed in dynamic apart from the gearbox?
  15. Bonstio
    116
    45
    I'm pretty sure it's Comfort even tho the display is lying. I.e. it's a software bug. Exhaust sounds like a Prius after the initial pops an bangs.
  16. KKOG
    89
    42
    Yeah I get that.
    But I wonder how the discussion went at Audi when they decided to visually let it be in Dynamic but in reality its in comfort on every start up.
    Cause, surely, they couldn't have failed such a obvious thing like that :expressionless:
    terminator x likes this.
  17. Bonstio
    116
    45
    IMHO
    Default to comfort => fine
    Mismatch between actual drive select mode and what's displayed on the MMI => almost certainly a bug
  18. Powerenhancer
    Powerenhancer Registered User
    164
    112
    43
    All manufacturers do the same. It is because the official type approved tests including fuel consumption, emissions etc. are based on the standard settings. Per regulations this is how the vehicle should perform when starting the vehicle.
  19. Behind The Bins
    Behind The Bins Registered User
    345
    258
    Ok I get that so why not just make it display comfort then, everyone’s happy
    KKOG likes this.
  20. AB RS3
    34
    You can go into drive select without turning the car on but like Billy said, you gotta wait for the system to 'initialise' for a couple seconds before you can change modes.
  21. AB RS3
    34
    Excuse me if I sound stupid but do you mean you can change modes from VC without the star button?
  22. AB RS3
    34
    d) put traction into sport*
    JamesCrs3 and Snake Pliskin like this.
  23. T-800
    T-800 Guest
    Mine will select modes as soon as I press the ignition on.
    The only time I’ve seen ‘initialising’ is when going into the MMI car menu.
    Doing it via the D/S button on the dash changes it straight away on mine as I can see the mode change in the VC.
    AB RS3, Dan_DJT and KKOG like this.
  24. KKOG
    89
    42
    Yes. Via the Drive Select button on the dash.
    On this topic, every time the star button doesn't work (70% of the times I press it) I envy the ttrs owners and their steering wheel :unamused:
    T-800 and Dan_DJT like this.
  25. terminator x
    4,703
    5,367
    If you hold the star button the star menu comes up allowing you to select what the star button does. Just click drive select option and carry on?
    TX.
  26. Powerenhancer
    164
    112
    43
    Most likely poor decision making by the Engineers. However, my RS6 did the same and I remember an occasion when it reverted back to Dynamic features on its own accord after a while of driving. Most of the time I would toggle through comfort/dynamic at start up like everyone else so never got the chance to test how long this took.
  27. T-800
    T-800 Guest
    Doesn't work @terminator x
    I've tried it selecting another function for the * button which works, but re-selecting drive select function and i get nothing.
    It's a bug that needs ironing out by an update i suspect
    I double checked this morning and the dashboard drive select button switches modes instantly as soon as the start button is pressed.
    KKOG likes this.
  28. terminator x
    4,703
    5,367
    Ah, no help to you then but sorted on the 4 as I can hold the star button and select what it does.
    TX.
  29. T-800
    T-800 Guest
    You can do the same on the 3 @terminator x
    The problem is it doesn't like Drive select for some reason :blink:
    But it seems ok with any other selection.......
  30. fastolsen
    fastolsen Registered User
    45
    106
    33
    Im getting used to press start/stop, drive Select 5 times and ESP once while starting the car. Little bit annoying though...
    AB RS3 likes this.
  31. teslaboy
    teslaboy Mythos black RS3 8v FL
    804
    502
    93
    Question to PFL owners, do your cars have the mad start up noise you get in the FL ?
  32. Bonstio
    116
    45
    Not heard a PFL but yes, I would describe the noise as mad, irrespective of drive select mode. But NOT at cold start. Cold starts are rather dull.
  33. Avatar
    snack-media
    Advertisement
  34. D0C
    D0C Registered User
    3,250
    3,069
    Oh yes! I've owned both and the PFL has the mad pops and bang start up and is just generally louder full stop.
    Marshy, teslaboy and DW81 like this.
  35. DW81
    DW81 Registered User
    1,164
    960
    A cold start in an underground carpark takes some beating on my PFL.
  36. terminator x
    4,703
    5,367
    Works fine on the 4 though eg hold star, select what you want and carry on as normal.
    TX.
    T-800 likes this.
  37. Snake Pliskin
    4,625
    6,922
    Hey TX ... do you have the same faff with the RS4 - that it defaults back to quiet mode too on start up ?
  38. Snake Pliskin
    4,625
    6,922
    Cold starts are MAD on the pre-face lift lol :tearsofjoy:
    Especially in a garage to amplify the noise even more :icon thumright:
  39. Snake Pliskin
    4,625
    6,922
    Agreed .... there is a shopping centre we visit every so often and whenever we get there, I wind the window down (wife frowns lol) and just can't help myself :laughing: :speakerthree::speakerthree::boom::boom::speakerthree::speakerthree:
    DW81 likes this.
  40. terminator x
    4,703
    5,367
    It does although not as noticeable as the RS3 ;) star button also stops working but easy fix by holding it down as above.
    TX.
    Snake Pliskin likes this.
  41. Snake Pliskin
    4,625
    6,922
    Ah right ... I wonder why Audi do this ??? :blink:
  42. T-800
    T-800 Guest
    Do what ?
  43. Snake Pliskin
    4,625
    6,922
    Default the car set up out of ‘loud mode’ into ‘quiet mode’ on every start up ... even in individual mode !
    It’s not like it quietens the car on cold start up is it ... it only affects warm start up in terms of noise volume.
