Hi to all,
I've noted that if I switch off the car in drive select mode EFFICIENCY with the indication on the CP Efficiency (Exx), when I switch on the car the drive select id set into EFFICIENCY (Dxx). To restore the Ex mode I need to set again the EFFICIENCY mode.
Is this correct ?
Thank you,
Enrico
Is this correct ?
Thank you,
Enrico
