  2. Dismiss Notice
DPF: Reading ash loading level @140,000 mi
kpm278 Aug 17, 2020
  1. kpm278
    kpm278 Registered User
    142
    15
    Hi all
    I'm checking my service intervals to see what needs doing next, and I noticed:
    first from 140,000 mi
    then every 20,000 mi
    What does that mean - have the DPF checked, or replaced?
    Does sonic cleaning for DPFs exist, is it snake oil or worth doing? Or just give it the old italian tune up?
    Thanks, Kristian
  2. Avatar
    snack-media
    Advertisement
  3. Peter82
    Peter82 Registered User
    452
    55
    Hi I had carbon clean last year in november or december I think it takes 30 mins.. £30
  4. Rideen
    Rideen Registered User
    1,152
    369
    Means you/your mechanic should do DPF ash reading - quite an easy thing to do with VCDS/OBDEleven.
    I think these filters hold up to 70g of ash (can be checked with the same diagnostic tool).
  5. cuke2u
    cuke2u Well-Known Member
    13,033
    5,277
    Doesn't a carbon clean just cleans the engine not the dpf?
    Retroman likes this.
  6. Peter82
    452
    55
    Yeah engine and turbo too. Guy sticked pipe into the air intake ... For 30 mins...
    No, no DPF... If you want dpf clean you need to remove part of exhaust with dpf and submerged it in ultrasonic bath dissolving chemical and then blow it with jet wash bigger job ...
  7. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,268
    415
    As above, carbon is not the problem with a DPF and so "carbon cleaning" will not help. The normal, healthy DPF is designed to burn off carbon (by its range of regens) and turn it into ash which is ejected from the exhaust. A tiny amount of this ash remains in the DPF and over a long period of normal usage this ash will build up and hamper the effectiveness of the DPF. Removing this ash is a specialist job which needs the DPF to be removed or completely replaced.
  8. Peter82
    452
    55
    Audis from 2013 has no issues with DPF at all.. never had problems over year only audis 2005 -2012 constantly popped up on dash..
