- Joined
- May 30, 2016
- Messages
- 71
- Reaction score
- 14
- Points
- 8
Ah ok,thanks, worth knowing,not noticed it before nowIt would appear that the label files are connected to coding and adaptation and diagnostic such as vcds .
Yea i remeber laughing at a thread on here about options,and someone saying "if you didnt add any options on an audi spec list.that you would probably just recieve an unpainted car body"yep, was an extra option on my old bus...but then even an option is an extra option with audi..lol
You may be right,bit complicated for me.all i know is coding that conv module,sends different instuctions to"reciever"switches,modules on the car,lol.....
back to this door module coding issue, it comes to mind that maybe the individual door modules cannot be accessed as they have no specific label file.
Whereas the main conv control module does, is it possible that the central conv module is the critical part of the equation from a coding point of view as it has a label file so must have a data function, whereas the door modules don't have a specific label file , just a though and maybe worth further investigation.
Yes i think thats correct,but only if the "recieving module "is able to accept it?but again im not sure ,its a bit technical for meJust another thought , address 46 is central conv but the door modules are listed as a sub-system .
the main module has a coding number which would relate to specific function it can and cant do etc, maybe by altering the coding of the main module it would relate to how the door modules operate.
for example a central conv module with the coding 07147 could have numerous other combinations that effect the door modules such as tilting and dipping aswell.
Just an update, I fitted my power folding mirrors today, all working well, I am so happy to get it all done. (thanks to the weather)
Just need to buy some new door clips, I have about 5 broken so just put drivers side door card back for now.
Suprised how many broke, I have a set of plastic trim tools but not much use with the the door card design.
I scanned mine this morning,i have codes 01331,01332,door control driver and passanger side (j386) 53-10,supply voltage too low- intermittent, but i also have,01559,01560, driver and passenger door,57-10-electric circuit failure- intermittent?mirrors working fine thoughGreat stuff! Its worth the effort to fit them in my opinion, i use mine every day. Have you run a scan after completing the job? Im curious to know whether you have the same codes as i got
