  2. Dismiss Notice
Door Electrics Dead. I’m at a loss.
tr7 Jul 31, 2020
  1. tr7
    tr7 Active Member
    170
    61
    Right, my doors all lock/unlock by remote central locking working fine.
    But none have power inside. No windows work front or rear or does the Central locking button on drivers door handle.
    Windows won’t go up and down by holding key buttons either.
    Fairly sure the rear speakers aren’t working either.
    I’ve had the door cards apart previously to fit BOSE speakers.
    All cables plugged in that I can see.
    Nothing in VCDS.
    Any ideas?
  2. Avatar
    snack-media
    Advertisement
  3. Donfero
    Donfero Active Member
    475
    117
    43
    Most likely you have a short circuit in the main door, or a damaged main unit.
    Sent from my TA-1004 using Tapatalk
  4. tr7
    tr7 Active Member
    170
    61
    Main unit as in? Box/electric window motor?
  5. tr7
    tr7 Active Member
    170
    61
    I have two cars here and a parts car.
    Just tired different electric window motors/in both front and rear drivers side doors and no change.
    Did see this before swapped the rear. Very strange
    That door was closed at the time and drivers front was open.
  6. Donfero
    475
    117
    43
    Are you swapping with the same part number?
    I suggest you swap the convenience ecu located under the driver seat.
  7. tr7
    tr7 Active Member
    170
    61
    Well some progress, the switches are now lighting up after removing all connecters and reconnecting but windows not working.
    But now also have a VCDS code
    02071 - Local Databus
    57-00 - Electric Circuit Failure
    Was same parts just from another S-Line but some numbers different on them but might just be the batch numbers/dates.
    Have replaced original motors now and reconnected all cables and it's done something.
  8. I'm Just Rob.
    I'm Just Rob. Moderating or something, Staff Member Moderator Gold Supporter VCDS Map User
    14,631
    6,826
    I'd say you have a wiring issue on that side or a module problem or both.
    Try changing the module and then doing a vcds check.
  9. tr7
    tr7 Active Member
    170
    61
    Has anyone encountered anything like this?
    Can one cable in one of the doors cause all 4 not to work at all?
  10. Donfero
    475
    117
    43
    Yes, it can cause even more.
  11. tr7
    tr7 Active Member
    170
    61
    Ok thanks. Going to take all four door cards off this evening and have a look at the Connivence module just in case for water.
    Car has been sitting for quite a while with the lockdowns and only driven one or two short drives a week.
