Is Rick doing that for you?
No mate, map being done by Ecotune... They've always done most of my work!
Apologies to Doogie for going on...but...
Do update your thread when this gets done...I'm very keen to see how it all goes.
Nice Xmas list there.
Aside from looks the R8 coilpacks won't add anything.
The RS pump may require some work to get it running correctly on the stock controller but that shouldn't be above a good tuner.
The cam cover can be problematic in many ways and the IE cover is made of aluminium and won't warp.
There shouldn't be issues running it unmapped as its using a PWM controller to control its delivery triggered by LP rail pressure.
Changing a stock cam cover and gasket will be time consuming but not difficult but I got rid of the whole thing for other reasons.
Injectors rarely cause problems.
What would you recommend as the best course of action?
Yeah Coilpacks were needing replaced anyway as I was getting an intermittent misfire on cylinder 4 on a cold start under load and on a warm idle. So narrowing down issues with the coils and plugs... hopefully they remedy, if not then its injector time.
Yeah, re- the lpfp.. done a bit of reading up on it and i'm of the understanding a few bits from the stock S3 lpfp need transferred over.
A good friend who worked as a Tech at Audi will be fitting it.
Would their be any issues fitting it unmapped, as in still running the APR stage 2+ file?
was gonnna give the rocker a go myself as from what i've been told its fairly straight forward no?
You can see problems with runing the RS pump and stock controller with software for stock lpfp. as Alex sayes the controller can overheat, becous it is only made for 10amp and RS pump can draw 20 amp. new software that calibrates the duty cycle can fix this . or you can install RS controller or a Torqbyte pm3 lpfp amplifier with the stock controller. pm3 will the do the power delivery work managed from the stock controller.
Where is best to get either the rs controller or the torqbyte amplifier?
£80 for RFD from Creation Motorsports on eBay. I used these on mine.That's one mean *** looking S3 you've got there mate and some highly impressive figures to match!
I've also got a black 07 S3 and after seeing your pictures I'll definitely be debadging the rear Audi rings of mine and Lamin-x the front & rear lights. I don't have the luxury of a pre-cut RS6 grill unfortunately so I'm just going to Plasti Dip the slats on mine black but leave the rings and surround chrome.
The intake manifold RFD was something I'd heard of before but not looked into until I read your thread, now that's yet another mod I've added to the list for when I go Stage 2+!! I notice on APR's website they're for sale at £193 but no option to buy them? http://www.goapr.co.uk/products/rfd_20t_ea113.html Considering they're just plates, would a cheaper alternative suffice? http://www.uspmotorsports.com/Engine/Air-Intake/2.0T-Intake-Manifold-Runner-Flap-Delete-Kit.html
The APR420 map requires you have the RFD installed. You will need it mapping in or a map that supports it to make the most out this mod. I had Revo 2+ when I installed the RFD. Revo said they don't support it but it ran OK before I upgraded to APR420.Cool, cheers for that mate.
I take it you got the tuner to take this into account when remapping it to get rid of the cold start up issue (from what I've read)? Did you notice any difference having the RFD?
Im still gutted that Wayne has told me that APR have kinda now pulled the plug on Launch control and Flat Shift for the APR add ons in the UK...
That now means that if i want to get Flat shift, i need to get a custom map and that isnt going to happen now as im happy with the APR stage 2 map! grrr
