Hi mate, I dont recognize or know the car but here is the MOT history from the past 12 years. Hope this helps making your decision to buy or not
Registration: V369RUD
Check Performed: 22 Feb 2018
Road Tax Status: Expired: 09 Feb 2018
MOT Status: Expires: 29 May 2018 (96 days left)
Vehicle Make:AUDI
Model: A3
Manufacture Year: 1999
Cylinder capacity: 1781 cc
Colour: BLACK
Fuel Type: Petrol
Wheel Plan: 2-AXLE-RIGID BODY
Vehicle Status: Taxed and due
Registration Date: November 1999
Vehicle Age: 18 Years
Exported: No
MOT History
Test Date: 30 May 2017
Expiry Date: 29 May 2018
Test Result: PASS
Mileage Recorded: 104,597 Miles
MOT Test Number: 8572 8596 6811
Test Date: 24 May 2017
Test Result: FAIL
Mileage Recorded: 104,550 Miles
MOT Test Number: 7289 7535 3539
Reason(s) for failure
- Nearside Inner Front constant velocity joint gaiter deteriorated to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
Advisory notice item(s)
- Extensive cracking in nearside front and offside front tyre sidewalls.
Test Date: 23 May 2016
Expiry Date: 25 May 2017
Test Result: PASS
Mileage Recorded: 100,878 Miles
MOT Test Number: 4196 1035 8016
Test Date: 26 May 2015
Expiry Date: 25 May 2016
Test Result: PASS
Mileage Recorded: 96,764 Miles
MOT Test Number: 5165 0684 5176
Test Date: 18 May 2015
Test Result: FAIL
Mileage Recorded: 96,701 Miles
MOT Test Number: 6876 8843 5177
- Rear Headlamp levelling device inoperative (1.7.2)
- Nearside Headlamp cleaning device inoperative (1.7.2)
- Offside Headlamp cleaning device inoperative (1.7.2)
- Offside Front Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
- Nearside Rear Road wheel cracked (4.2.A.1a)
- Nearside Rear Road wheel distorted (4.2.A.1a) Dangerous
- offside front tyre rubbing on inner wheel arch
Test Date: 20 May 2014
Expiry Date: 19 May 2015
Test Result: PASS
Mileage Recorded: 91,563 Miles
MOT Test Number: 3599 9004 4108
- Offside Rear Anti-roll bar linkage has slight play in a pin/bush (2.4.G.2)
- Front and rear wheels do not match
Test Date: 19 May 2014
Test Result: FAIL
Mileage Recorded: 91,558 Miles
MOT Test Number: 7459 8993 4163
- Front registration plate insecure (6.3.1b)
- Windscreen has damage to the swept area in excess of a 40mm circle outside zone 'A' (8.3.1d)
- Windscreen washer provides insufficient washer liquid (8.2.3)
- Nearside Front Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
- Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Test Date: 29 April 2013
Expiry Date: 28 April 2014
Test Result: PASS
Mileage Recorded: 83,817 Miles
MOT Test Number: 6281 9981 3153
- Nearside Front Tyre worn close to the legal limit (4.1.E.1)
- rear suspension sensor linkage broken
Test Date: 25 April 2013
Test Result: FAIL
Mileage Recorded: 83,815 Miles
MOT Test Number: 4255 5551 3115
- Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
- Supplementary Restraint System warning lamp indicates a fault (5.4.2)
- Offside Windscreen wiper blade missing (8.2.2)
- Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
- Offside Rear coil spring incomplete (2.4.C.1a)
Test Date: 11 April 2012
Expiry Date: 10 April 2013
Test Result: PASS
Mileage Recorded: 78,896 Miles
MOT Test Number: 8850 3250 2197
Test Date: 4 April 2011
Expiry Date: 3 April 2012
Test Result: PASS
Mileage Recorded: 74,131 Miles
MOT Test Number: 5567 2409 1003
Test Date: 19 November 2009
Expiry Date: 18 November 2010
Test Result: PASS
Mileage Recorded: 70,456 Miles
MOT Test Number: 5332 1322 9378
- Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
- Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Test Date: 11 November 2009
Test Result: FAIL
Mileage Recorded: 70,099 Miles
MOT Test Number: 4105 7551 9494
- Offside Rear coil spring fractured (2.4.C.1a)
- nearside front brake disc inner face reduced by rust
Test Date: 13 November 2008
Expiry Date: 13 November 2009
Test Result: PASS
Mileage Recorded: 66,547 Miles
MOT Test Number: 6533 3881 8335
- Offside Front Tyre worn close to the legal limit (4.1.E.1)
- Nearside Front brake disc slightly pitted (3.5.1h)
Test Date: 14 November 2007
Test Result: FAIL
Mileage Recorded: 62,941 Miles
MOT Test Number: 2249 4811 7321
- Nearside Headlamp aim too low (1.8)
- Offside rear brake grabbing slightly (3.7.A.5b)
Expiry Date: 13 November 2008
Test Result: PASS
MOT Test Number: 7636 4861 7376
Test Date: 10 July 2006
Expiry Date: 9 July 2007
Test Result: PASS
Mileage Recorded: 53,853 Miles
MOT Test Number: 4012 9159 6180
