  2. Dismiss Notice
Does anyone have Audi Sound System without Tech Pack?
Zak0123 Feb 19, 2016
  1. Zak0123
    Zak0123 Active Member
    540
    77
    As per the title, trying to install the *** and have tried to code it in via VCDS but have had no luck (sub and centre speaker output aren't live).
    Can anyone post up their MMI coding up? I believe it is 5F in VCDS. Massive thanks owed if you can!
    Cheers folks!
  2. Avatar
    snack-media
    Advertisement
  3. Kugaman1
    Kugaman1 Well-Known Member
    679
    605
    93
    Hi mate,
    Ive got *** without tech pack.
    Tell me EXACTLY what you need from me and I will hook up my VCDS this afternoon to sort you out.
    Just send me a message if thats easier?
  4. Zak0123
    540
    77
    LEGEND! Sending a pm now. :friends:
  5. H17YD L
    H17YD L Active Member
    381
    76
    I have it too if your struggling mate
  6. Zak0123
    540
    77
    Cheers H17YD L, big help!
  7. Kugaman1
    679
    605
    93
    Hi Zak....
    OK Im not a VCDS wizard and couldn't be sure how to get what you need so Ive done a full scan, details as below...
    VCDS Version: Release 15.7.3 Running on Windows 7 x86
    Data version: 20151216
    www.Ross-Tech.com
    Saturday,20,February,2016,15:01:55:00188
    Chassis Type: 8V (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 22 42 44 52 55 5F A9
    VIN: WAUZZZ8V4FA143888 Mileage: 5015km-3116miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    Address 01: Engine (J623-CJXC) Labels: 06K-907-425-V1.clb
    Part No SW: 8V0 906 259 A HW: 06K 907 425 B
    Component: 2.0l R4 TFSI H13 0003
    Revision: --H13---
    Coding: 0A1900322426010B2004
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM20TFS0208V0906259A 001005
    ROD: EV_ECM20TFS0208V0906259A.rod
    VCID: 3E748999A17709CE43-806A
    2 Faults Found:
    16452 - Implausible Data Received from ESP Control Module
    U0416 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    17178 - Databus
    U1123 00 [032] - Received Error Message
    Freeze Frame:
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
    Component: ESC H42 0610
    Revision: 00000000 Serial number: 60615000001967
    Coding: 32F193A254242A6F017F070841CB694CC92A5480E08296F6024100788208
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
    ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
    VCID: 4898EF41F3B3477EF9-801C
    No fault code found.
    Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
    Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
    Component: AC Automat H13 0060
    Revision: 20027000 Serial number: 00000000582192
    Coding: 03100004000000011000000000001100
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 3362A8AD9A35D4A6BC-8066
    Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
    Component: BCM MQBAB H H18 0137
    Serial number: 01011505804636
    Coding: 07040A46C24122F503844004B31C07A80000000000000000000000000000
    ASAM Dataset: EV_BCMCONTI 013000
    ROD: EV_BCMBOSCH_AU37.rod
    VCID: 000837619B03BF3E71-8054
    Slave 1:
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 150220 041 0580
    Serial number: 150222235236
    Coding: 0A47F7
    Slave 2:
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 23756959
    Coding: 00006C
    Slave 3:
    Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
    Component: E1 - LDS MQB H05 0032
    Serial number: 02 12 2014 00000133
    Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0315
    Serial number: 000000000ZY150333P4B
    Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000061733638
    Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
    Part No SW: 5Q0 919 283 E HW: 5Q0 919 283
    Component: PARKHILFE 4K H10 0051
    Revision: -------- Serial number: 39231505704612
    Coding: 0000050001
    ASAM Dataset: EV_EPHVA14AU3700000 002022
    ROD: EV_EPHVA14AU3700000_AU37.rod
    VCID: 3B72808DB2651CE664-806E
    Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
    Component: AirbagVW20 011 0361
    Serial number: 003M2R0AMFU2
    Coding: 98CCC0000C0000005C5400CA00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    ROD: EV_AirbaVW20SMEVW37X_AU37.rod
    VCID: 4B92D04DE2C5AC66D4-801E
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: ----------- HW: 480 002 502 15
    Component: SideSensor_Df 001 0887
    Serial number: 35767000000E7AAC7316
    Coding: 2D2D2D
    Crash sensor for side airbag; front passenger side:
    Subsystem 2 - Part No SW: ----------- HW: 480 002 502 15
    Component: SideSensor_Pf 001 0887
    Serial number: 35867000000D5AAC7314
    Coding: 2D2D2D
    Crash sensor for side airbag; rear; driver side:
    Subsystem 3 - Part No SW: ----------- HW: 480 401 902 15
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502C91993FC2812J
    Coding: 2D2D2D
    Crash sensor for side airbag; rear; passenger side:
    Subsystem 4 - Part No SW: ----------- HW: 480 401 902 15
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502A51993FB1612A
    Coding: 2D2D2D
    Crash sensor for front airbag; driver side:
    Subsystem 5 - Part No SW: ----------- HW: 480 402 301 15
    Component: FrontSensor_D 001 6149
    Serial number: 35565029B19121A1F325
    Coding: 2D2D2D
    Pedestrian protection crash sensor; driver side:
    Subsystem 6 - Part No SW: ----------- HW: 480 401 302 15
    Component: PedP_Sensor_D 001 6149
    Serial number: 22865029B1993FC3F19-
    Coding: 2D2D2D
    Pedestrian protection crash sensor; front passenger side:
    Subsystem 7 - Part No SW: ----------- HW: 480 401 302 15
    Component: PedP_Sensor_P 001 6149
    Serial number: 2296502991993FC283AU
    Coding: 2D2D2D
    Center pedestrian protection crash sensor:
    Subsystem 8 - Part No SW: ----------- HW: 480 400 902 15
    Component: PedP_Sensor_C 001 6149
    Serial number: 2306502A5198E1558143
    Coding: 2D2D2D
    Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
    Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
    Component: Lenks. Modul 002 0110
    Revision: -------- Serial number: 02031504220258
    Coding: A408
    ASAM Dataset: EV_SMLSKLOMQB 017001
    ROD: EV_SMLSKLOMQB_AU37.rod
    VCID: 091E2A45A839FE7626-805C
    Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
    Part No SW: 8V0 920 971 J HW: 8V0 920 971 J
    Component: KOMBI H02 4292
    Coding: 27AD08022B8026000101EA001000000000000000
    Shop #: WSC 12679 002 104857
    ASAM Dataset: EV_DashBoardVDDMQBAB 009046
    ROD: EV_DashBoardVDDMQBAB_AU37.rod
    VCID: 4480FB71CF9B631E15-8010
    Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
    Component: GW MQB High 128 1204
    Revision: -------- Serial number: 0003128935
    Coding: 030100043F085A005B000268080B00000001010000000000000000000000
    ASAM Dataset: EV_GatewLear 011020
    ROD: EV_GatewLear.rod
    VCID: 72EC6DA9A5AF9DAE77-8026
    Alternator:
    Multifunction unit control module:
    Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
    Component: E221 - MFL H02 0014
    Serial number: 13 02 2015 C0042606
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
    Component: J367-BDMConti H02 1011
    Serial number: 74185703001502063384
    Address 22: AWD (J492) Labels: 0CQ-907-554.clb
    Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
    Component: Haldex4Motion H52 7082
    Serial number: HA1-00002.02.15
    Coding: 0001
    ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
    ROD: EV_AllWheelContrHA1VW37X_AU21.rod
    VCID: 4684E179F9A7510E0B-8012
    Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
    Component: TSG FS 020 0028
    Serial number: 150215BB909475
    Coding: 00108E204001040000001002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
    VCID: 428CFD69D58F6D2E27-8016
    Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
    Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
    Component: EPS_MQB_ZFLS 505 5061
    Coding: 8103
    ASAM Dataset: EV_SteerAssisMQB 012140
    ROD: EV_SteerAssisMQB.rod
    VCID: 377A9CBD8E4D388680-8062
    Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
    Component: TSG BFS 020 0028
    Serial number: 130215BBC17228
    Coding: 001086204C01040000001002
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
    VCID: 418EF265D08976363E-8014
    Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0080
    Revision: -------- Serial number: --------------
    Coding: 01AE000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
    VCID: 75E656B5D4C18A9652-8020
    Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-STD1.clb
    Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
    Component: MU-S-ND-ER 041 0420
    Serial number: A7F02202150132
    Coding: 01730301FF0A000021111101000A00002F0005060100010006
    Shop #: WSC 12679 002 1048576
    ASAM Dataset: EV_MUStd6C3PASE 002020
    ROD: EV_MUStd6C3PASE_AU37.rod
    Engine Control Module 2:
    Subsystem 1 - Part No SW: 8V0 919 866 C HW: -----------
    Component: ECE 2015 --- 0045
    Serial number: --------------------
    Seat Adjustment Driver Side:
    Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
    Component: DU Std H49 0014
    Serial number: AUZ8Z9EY309QGY
    Sound System:
    Subsystem 3 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
    Component: ControlUnit_B H41 0054
    Serial number: C1000008121400010242
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 8V0 907 159 HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0012
    Serial number: 150213201211
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 7DF64E95ECF1D2D61A-8028
    End-------------------------(Elapsed Time: 04:02)--------------------------
    Zak0123 likes this.
  8. Pureangel
    Pureangel New Member
    24
    Kugaman thnx for posting, I am in the same situation like Zak.
    Zak, did you sort it out mate? Hope something good will come up :)
    Please let me know..
    Alex
  9. Schizophonic
    Schizophonic Well-Known Member
    1,120
    568
    Is it just the centre speaker and *** sub you got installed? Was it easy to all wiring in? Can you post the part number of the *** sub, I know there is the B&O sub but is that a different dimension?
  10. Zak0123
    540
    77
    Hasn't worked :(
    Thanks for you help Kugaman1, tried the coding and the speakers still aren't live. Scratching my head over this one :shrug:
    All I got from running a fault scan is 'Control Module incorrectly coded' and front and left bass speaker open circuit, 3 faults in total. Tried the wires with a voltage metre and a speaker and no luck. Not sure what to do next ahhhhh! :sob:
    Not sure on the dimensions bud but the part number for the sub is 8V0035382. Haven't done the wiring completely yet as I want to get all the speakers enabled and then will dive in.
    If anyone can help on a solution that would be amazeballs, not sure where to go from here....:blink:
  11. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,842
    4,756
  12. Avatar
    snack-media
    Advertisement
  13. Zak0123
    540
    77
    Cheers Veeeight, read through both of those and have tried both the following codes with no luck:
    01730301FF0A000021111101000A00002F00020701000100DE
    My car is 65 plate so I'm guessing it may be locked down?
  14. Zak0123
    540
    77
    This is the coding I tried today...
    Ran a scan for faults and got these 3 errors...
    _
  15. Zak0123
    540
    77
    I've also installed the *** front door speakers so not sure if this is what the faults mean, they do seem to be working fine though.
    EDIT: When I tried the original code,
    It said something along the lines of code rejected, so maybe you're right about it being locked down Veeeight.
  16. Pureangel
    24
    Well my car is 12/2013 and changing FF00 to FF0A does nothing..
    MMI unit is panasonic with HW: 8V0 035 864
  17. Zak0123
    540
    77
    If you scan for faults after you change the code, does anything show?
  18. Pureangel
    24
  19. Zak0123
    540
    77
    Has anyone else had any luck with either of the above coding?
    @Kugaman1, what year is your car?
  20. Kugaman1
    679
    605
    93
    Zak its a 2015 was built in March.
  21. Zak0123
    540
    77
    Cheers Kugaman1, mine is 65 so don't think much will have changed. Thinking now I will have to take it into Audi to see if they can sort it out.
  22. h5djr
    h5djr Well-Known Member Gold Supporter VCDS Map User quattro Audi A3
    9,615
    1,926
    It might be worth giving Quattro-Tech in St Ives a ring. I think they will be more willing to set things up using VCDS that a normal dealer. They were certainly happy to make a couple of VCDS changes to my wife's Polo which the VW dealer would not do for her.
  23. Zak0123
    540
    77
    Dave I'd actually already booked it in with them following your advice on Sunday, hoping they can get it sorted when I go in in a couple of weeks. Thanks for the tip!
