Q5 DLR Fault - error warning on Dash
Daniel James
Hi all,
over the past month or so I keep getting a warning light and my DLR on the drivers side isn't working.
Has anyone experienced this previously and is it a common / easy fix ?
not sure if this is a bulb or a module or even worse a wiring and electric fault :crying:
NHN
Site Sponsor
If they're xenon's, then they're led DRL & tbh needs headlight, halogen, then check the bulb.
Daniel James
hi, yes Xenon's, i find it hard to believe that ill need a complete new headlight just for the day light running light? surely this is something to do with a faulty module or something ?
NHN
Site Sponsor
Tbh without knowing the year & headlight part number, details etc, can't help more, it sometimes has a separate driver module, but from my experience, if the led part has a fault, it's usually internal not so much a bolt on module.
It's time, money scenario, time taken to attempt repair & possibly fail, against replacing parts to fix with minimal time taken.
Daniel James
Hi, yes that makes sense in what you are saying,
i've read a few mixed things and kind of ruled out certain, its a 2015 Sline so heard that the DLR's are common for fault
NHN
Site Sponsor
Are they adaptive as in turn with corners or standard bixenons?
Part number label maybe shown on the top of the headlight if visible, can't recall tbh.
Daniel James
hiya, they are standard bixenons, i will try and remember to try and get a snap of the label later
NHN
Site Sponsor
You were given advice before, try swapping headlights, not allot more can be done.
