- Joined
- Aug 8, 2007
- Messages
- 244
- Reaction score
- 6
- Points
- 18
Hi,
I have been researching the S3 PCV system (BAM engine) as I am trying to fix a whooshing sound when the turbo spools.
So far I have repaired 2 split hoses under the inlet manifold, but it still makes the sound. I'm in the process of checking all hoses, TIP etc. and found the PCV valve near the block to not quite close fully when testing (new one on the way).
My question is around the diverter valve. I decided to test the DV as I am checking all hoses. According to some guides, to test the DV carefully push the internal piston and put your finger over the top pipe fitting - if it holds (and mine does) then the DV is ok. But to push the piston up takes quite a lot of effort as its quite stiff.
Is this normal for the DV to be hard to push the piston? I use a socket on an extension. Thanks
